RSS discussions
Discussion Discussion forum
Topic Closedcan't change setting
 Post Reply Post Reply
Author
lmits View Drop Down
Groupie
Groupie
Using: autocad 2017
Status: Offline
Direct Link To This Post Topic: can't change setting
    Posted: 01.Mar.2013 at 22:58
I am running autocad 2002 and today the point style will not allow me to change the point size and in options under display it will not allow me to change the arc and circle smoothness setting. I have never had this happen before and I don't know how to fix it can anyone please help?
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 02.Mar.2013 at 20:04
Arc and circle smoothness can be addressed via the VIEWRES command.  Use a setting of 5000.
Point size and type are governed by the PDMODE and PDSIZE commands.
So what you are saying is that none of these commands can be accessed?
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Using: autocad 2017
Status: Offline
Direct Link To This Post Posted: 04.Mar.2013 at 16:42
I can bring the commands up however I can't change the setting it's stuck. Point style is stuck on 5 and I want 1. Arc and circle is stuck on 100 and I wanted 3000. I don't know what to do.
Back to Top
Groupie
Groupie
Using: autocad 2017
Status: Offline
Direct Link To This Post Posted: 04.Mar.2013 at 17:54
got it thanks John
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 04.Mar.2013 at 18:41
So how did you fix the problems?
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Using: autocad 2017
Status: Offline
Direct Link To This Post Posted: 11.Mar.2013 at 22:08
I re-installed autocad
Thanks
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,193 seconds.
