RSS discussions
Discussion Discussion forum
Topic ClosedPROBLEMS WITH COPYCLIP
 Post Reply Post Reply
Author
jmontesmx View Drop Down
Senior Member
Senior Member
Using: AutoCad2017
Status: Offline
Direct Link To This Post Topic: PROBLEMS WITH COPYCLIP
    Posted: 15.Aug.2013 at 00:43
I'm having problems with copyclip, I received a draw to make some changes, I decided make a new draw and use some objects of the original  base draw, but when I copy that objects appears that doesn't exist selected objects, try different ways but always appear same answer, I will appreciate if somebody can help me.
thanks
Back to Top
heinsite View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 15.Aug.2013 at 07:53
What happens if you select all your objects in Drawing #1 with Ctrl-Shift-C (Copy w/ basepoint) and Ctrl-V (paste) them into Drawing #2 that way?  Make sure you have PICKFIRST=1.
I have seen a number of threads, especially for users on AutoCAD 2010, talking about issues with COPYCLIP.
Dave.
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 15.Aug.2013 at 11:48
Is your version of AutoCAD up to date with all service packs?
So you copy from one drawing and paste to another but you don't see the objects?  Did you do a Zoom > All or Zoom > Extents?
Did you check to see if any layers were turned off or frozen?
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCad2017
Status: Offline
Direct Link To This Post Posted: 16.Aug.2013 at 01:28
Thanks for your advice, I try to solve them as well but the problem continues , I found how to copy objects using Drawing utilities  with the recover command first and then use ctrl-shift-c to copy otherwise not be done.
Regards.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 16.Aug.2013 at 04:26
Hopefully you have found a solution, but if not, post another question with more details and we'll see what we can do to help.  Without seeing your drawing or what happens when you try to move objects from one to another it is difficult to give you accurate answers.
And it is never easy to solve technical questions when there are language translation issues either.  One idea might be for you to re-post your problem in your native language.  We can then use online translator or someone who reads it natively can help.  Still lots of options open here.
Dave.
Dave Hein, P.E.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 16.Aug.2013 at 11:47
I'm left wondering how the RECOVER command somehow helps you with COPY/CLIP.
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,145 seconds.
