Discussion forum
Post Reply
| Author | |
kicker
Newbie
Joined: 04.Sep.2013 Location: Portugal Using: Autocad 2012 Status: Offline Points: 16 |
Topic: Help On dimensions ....Posted: 05.Sep.2013 at 00:16 |
Hello Hello...
I need a bit of help in one thing. where can i find here in the Forum some standard dimensions to calibrate ?? Because the Autocad that i have only have one option...normally it has more than one option... Thanks... :)
philippe JOSEPH
Senior Member
Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1538 |
Posted: 05.Sep.2013 at 07:29 |
Hello kicker, you have AutoCAD 2012, use the command DDIM to set new dimension styles and when you have set a good one for you, save the file as a "standard file" or save it as a .dwt file for you to use an other time.
DDIM, new, give a name for your dimension style ( with the scale if you want to work directly from the object space ), proceed, set the values in each panel ( a modification will modificate the little drawing showing dimensions on the top left of your screen ), define as current, OK.
Beware of seting correctly the panel N° 4 FIT with the good option in : scale for dimension feature.
Beware of seting correctly the panel N° 5 PRIMARY UNITS, etc...
Ask for more and tell us if you are using AutoCAD recently, what you are doing with it, etc...
Take a look at this site : http://www.we-r-here.com/cad/tutorials/level_4/4-11.htm
John Connor
Senior Member
Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 05.Sep.2013 at 11:39 |
What field do you work in? Mechanical, architectural, other?
Create your own dimension style(s) and make it/them part of your template so every time you start a new drawing it already has it incorporated thus saving you the time and effort of either recreating the dimstyle from scratch or bringing it in from another drawing via the Design Center (drag and drop). Another option would be to put your custom dimstyle on a Tool Palette. |
<<AutoCAD 2015>> |
kicker
Newbie
Posted: 05.Sep.2013 at 12:19 |
Thanks for the answers... it are helpfull...
but i think i didnt express myself very well... :) i work in mechanical... pipelines... structures..... i was asking if in the forum has any dimension styles already defined .... and then i could add those new dimension styles.... normally what kind of values do you use for the dimension style...? yes i know that i need to create my own :) cheers :)
philippe JOSEPH
Senior Member
Posted: 05.Sep.2013 at 13:08 |
Hello again kicker, to have an easily setable dimension style I propose to create 2 dimension styles :
1 for the formats A0 to A1 with the text height at 3.5 mm + arrow length 3.5 mm
1 for the formats A3 and A4 with the text height at 2.5 mm + arrow length 2.5 mm
Fraction height text : 1 mm ( space under the text ).
This helps for a good readability on the A0 to A3 reduced on A3 formats.
If you do this you just have to set a new FIT with the good option in : scale for dimension feature.
You set it to 50 for a drawing at scale 1/50.
John Connor
Senior Member
Posted: 05.Sep.2013 at 14:09 |
Doesn't Portugal have a recommended industry "standard" for drawings? Or does it have to follow the standards that were adopted by the EU?
<<AutoCAD 2015>> |
kicker
Newbie
Posted: 05.Sep.2013 at 19:39 |
Thx for both answers :)
Here we use the same standards that are use in EU. but of course it always depends the project that we are doing... if its british... will be british standars , same to american... .. etc... Thx again.
John Connor
Senior Member
Posted: 05.Sep.2013 at 20:12 |
Looks like you'll have more than one dimstyle to create.
<<AutoCAD 2015>> |
Post Reply
Tweet
This page was generated in 0,801 seconds.
Topic Options
