RSS discussions
Discussion Discussion forum
Topic ClosedErrors and Crash
 Post Reply Post Reply
Author
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Topic: Errors and Crash
    Posted: 09.Sep.2013 at 18:29
Then it is a bad install or you files are being corrupted somehow.
<<AutoCAD 2015>>
Back to Top
crelph View Drop Down
Groupie
Groupie
Using: Draftsight
Status: Offline
Direct Link To This Post Posted: 09.Sep.2013 at 16:08
I am very familiar with this product-Draftsight.
Connor
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 07.Sep.2013 at 12:26
If it happens in almost any drawing you are working in then I would suspect a problem with the installation.  The only other possibility that I can think of would have to do with your technique.  Remind us again as to your background using CAD programs.
Edited by John Connor - 07.Sep.2013 at 12:29
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Using: Draftsight
Status: Offline
Direct Link To This Post Posted: 06.Sep.2013 at 22:22
Not Complex at all.
Only a couple websites,my email and a couple search bars.
I was able to recover the document but I could not connect two line segments together.
The problem is repeatable on the same drawing, no matter how many times you try.
I even shut down the computer but it did not help.
It happens in multiple different drawings.
The measurements for both lines are the same, meaning by the measurements they are the same, but there is a gap when you zoom in. Which would not be a problem if I could move them together.
Is that better information?
Connor
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 06.Sep.2013 at 21:42
The messages you have received do not give any hint as to what the cause of the problem might be so basically we have very little information to go on other than you were trying to move and object with ESnaps enabled and it failed.
Was this a fairly complex drawing (lots of objects)?
What else was up and running on your computer when the problem happened?
Did you recover the drawing then reopen it?  If so what happened next?
Is the problem repeatable in the same drawing?
Is the problem repeatable in a new drawing?
Edited by John Connor - 06.Sep.2013 at 21:47
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Using: Draftsight
Status: Offline
Direct Link To This Post Posted: 06.Sep.2013 at 19:45
I tried positing this to draftsight but there were problems during the process.
The problem:
When I try to move one line to meet up with another the following happens: first it does not connect to the original line when Esnap is on, then when I try to continue to move it nothing happens. Then I click the screen one more time and it starts shutting down with error messages.
I would appreciate any help.
Thank you in advance for your time.
Pictures below
I said no, then:
Basically saying it will save a recovery file, I said yes.
Then:
I am able to look at the report but I do not understand it because it is all code.
Can I get some help please.
Connor
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,119 seconds.
