RSS discussions
Discussion Discussion forum
Topic Closed"archstyl" not displaying
 Post Reply Post Reply
Author
sanbar406 View Drop Down
Newbie
Newbie
Using: AutoCAD 2013
Status: Offline
Direct Link To This Post Topic: "archstyl" not displaying
    Posted: 08.May.2014 at 20:23
Please help!!!
I'm running AutoCAD 2013, but can't get the archstyl.shx to display.  I checked and double-checked everywhere that the file should be loaded and still not getting the correct display.
Any help would be great.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 09.May.2014 at 00:20
Are you sure you have the font and not the shape file?
If it is a font file where did you put it on your hard drive?  What folder?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: AutoCAD 2013
Status: Offline
Direct Link To This Post Posted: 09.May.2014 at 16:25
I put the file in the AutoCAD 2013 font folder. It is showing 'archstyl' as active in the mtext editor, but does not display it in the preview window of the editor or after exiting the editor.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 09.May.2014 at 16:34
OK...I found the file online and have been able to reproduce your problem.  Let me see if I can come up with a solution.
I think I see what is happening.
When you go looking for the font it seems as though it is not listed.  The list of fonts, at least in my case, starts with Arial.ttf which appears at the very top of the window.  Scroll UP one entry and you should find Archstyl.shx listed.  I did and I was able to load and use it in my test drawing.  I can even post an image if you'd like.
BTW...I was able to use the font in both single line and multiline text.
Edited by John Connor - 09.May.2014 at 17:02
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: AutoCAD 2013
Status: Offline
Direct Link To This Post Posted: 09.May.2014 at 19:25
John, thank you. I looked for 'arial.ttf', but it was in an obscure Windows folder: [C:\Windows\winsxs\amd64_microsoft-windows-font-truetype-arial_31bf3856ad364e35_6.1.7601.17621_none_d09ba6bac4056b40].  I have a strong feeling that loading 'archstyl.shx' in that directory wouldn't help because it says it's a backup directory.  If you don't mind, I think I'll take you up on your offer of posting that image.
Thanks again, sanbar406
Back to Top
Newbie
Newbie
Using: AutoCAD 2013
Status: Offline
Direct Link To This Post Posted: 09.May.2014 at 19:59
John, I got it.  It may have been the 'archstyl.shx' file itself.  I downloaded another of same from a different location, plugged it into the same directory as previous, opened AutoCAD, changed the style in 'mtext' editor and voila, it worked.
Thank you again for your assistance,
sanbar406
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 09.May.2014 at 21:36
All Windows fonts should be in the Fonts (note the "s") sub-folder in the Windows main folder on the root drive of your computer.  Anyways, you wouldn't put a SHX font in that folder since it really belongs in the AutoCAD font folder.
Edited by John Connor - 09.May.2014 at 21:37
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,088 seconds.
