RSS discussions
Discussion Discussion forum
Topic ClosedQuick Property problem
 Post Reply Post Reply
Author
Jacqui B View Drop Down
Newbie
Newbie
Using: Autociv 3D
Status: Offline
Direct Link To This Post Topic: Quick Property problem
    Posted: 18.Sep.2014 at 09:46
The customization of the Quick Properties dialogue no longer works. The error message Microsoft .NET framework has an "Unhandled exception error occurs" message.
Any ideas of how to solve this PLEASE!!
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 18.Sep.2014 at 11:39
Not sure how one actually affected the other.  I'd uninstall then reinstall .NET framework and see if that solves the problem.
Did you visit the AutoDesk website and search on the .NET framework error message?  Maybe someone has had a similar problem and found an answer for it already.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: Autociv 3D
Status: Offline
Direct Link To This Post Posted: 18.Sep.2014 at 11:46
Thanks for your quick reply.
We have uninstalled and re-installed.
We got feedback from Autodesk but nothing has helped.
Some on the machines in the office still work perfectly and others don't. We have compared machines but just cannot come up with a solution.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 18.Sep.2014 at 13:07
What exactly did you uninstall/reinstall?  Was it .NET Framework?  Please don't tell me you uninstalled/reinstalled AutoCAD.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: Autociv 3D
Status: Offline
Direct Link To This Post Posted: 18.Sep.2014 at 13:37
The whole problem started when the firm's server was replaced with a Linex server. We had to re-install AutoCAD on all machines after that. Hence the customization stopped working. So we re-installed .NET framework. What is puzzling is that the one machine still works perfectly.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 18.Sep.2014 at 14:00
Then it sounds like the customized CUIx is the problem.  Restore the original CUIx and test the computer.  What happens?
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,187 seconds.
