Over 1.132.000 registered users (EN+CZ).
Discussion forum
Post Reply
| Author | |
jcastle
Newbie
Topic: HELP!Posted: 03.Sep.2008 at 17:21 |
you will want to import a layout for your drawings. there will be a second pull down menu afterwards where you can select pdf, printers, etc...
zhb7
Groupie
Joined: 26.Apr.2008 Location: Canada Status: Offline Points: 31 |
Posted: 03.Sep.2008 at 15:31 |
morning!
thanks for the answers
I got one more question here now. how can get to pdf file when I use publish because it always shows publish to dwf . how can I switch to pdf.
thks!
Vladimir Michl
Moderator Group
Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2188 |
Posted: 03.Sep.2008 at 09:35 |
You can use any batch plot tool (ScriptPro, Publish, Sheet Set Manager...) to plot your DWG drawings to PDF. Either to a single multipage PDF or to multiple PDF files.
Vladimir Michl (moderator)
zhb7
Groupie
Posted: 02.Sep.2008 at 20:07 |
HI EVERYONE.
I WANT TO CONVERT A LOT OF DWG FILES TO PDF, IS THERE ANY POSSIBLE I CAN DO THIS ONLY ONCE, NOT ONE BY ONE.
THKS !
Post Reply
Tweet
This page was generated in 0,153 seconds.
HELP!
Topic Options
