RSS discussions
Discussion Discussion forum
Topic ClosedMousewheel pan problem.
 Post Reply Post Reply
Author
Anders79 View Drop Down
Groupie
Groupie
Using: AutoCAD 2012 lt
Status: Offline
Direct Link To This Post Topic: Mousewheel pan problem.
    Posted: 16.Mar.2015 at 17:10
Hello.
I have lately experienced a very annoying problem with the mouse-button pan:
Sometimes the mouse gets stuck in the pan-mode, and I have to press esc-key to get free.
Sometimes pressing the wheel displays the right-click button menu instead of the pan-mode.
Sometimes after releasing the wheel, it displays the right-click button menu or the left-button selection frames insead of just releasing the pan mode.
The wheel-zoom works fine as usual.
I have done nothing: No hardware of software Changes, it just hapened one day.
Any ideas?
Command: oops
Back to Top
Robert_D View Drop Down
Senior Member
Senior Member
Using: BricsCAD v25, AutoCAD2006
Status: Offline
Direct Link To This Post Posted: 16.Mar.2015 at 17:26
I assume you've tried another mouse?
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 16.Mar.2015 at 17:31
The day that this "just happened" was the day you ate lunch at your desk wasn't it?
Did you unplug your mouse then plug it back in?
Did you shut down AutoCAD then restart it?
Are you experiencing mouse related problems in other programs?
Did you shut down your computer, wait 20-30 seconds, restart it, load AutoCAD and test it?
What else did you do to troubleshoot the problem?
Edited by John Connor - 16.Mar.2015 at 17:33
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 17.Mar.2015 at 15:48
I spilled som guacamole on it, but that can't be it since i spilled even more on the keyboard and it works fi&3.§3..(€
Tried that - no effect.
I shut down the computer totaly every night - no effect.
Nope. Works perfectly in all other programs (and games).
Not much... Disapprove
Command: oops
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 17.Mar.2015 at 17:37
Robert wants to know if you tried another mouse.  How long have you been using this problematic mouse?
What other problems are you experiencing with AutoCAD?
Do you have the latest mouse drivers installed?
Edited by John Connor - 17.Mar.2015 at 17:39
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 18.Mar.2015 at 12:21
Problem solved!
I changed mouse with a collegue, and now it works fine. He's on the economy-side and does'nt need any nifty CAD mouse-features to run his programs. The mice looks just the same so I hope he doesn'nt notice the change, since I sort of forgot to ask him...
Command: oops
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 18.Mar.2015 at 12:44
In the future when you have a problem with a mouse the smart thing to do is to swap it for another one.  It is also the easiest thing to do.
Glad to hear you solved your problem even though it meant stealing your coworker's mouse.  Thanks for updating us.
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 18.Mar.2015 at 15:52
Originally posted by Anders79 Anders79 wrote:
Problem solved!
I changed mouse ...and now it works fine...
That was easy!
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 18.Mar.2015 at 17:13
Funny how the simplest things somehow elude us.
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,079 seconds.
