RSS discussions
Discussion Discussion forum
Topic ClosedHelp modeling part
 Post Reply Post Reply
Author
mmaurigi View Drop Down
Groupie
Groupie
Using: AutoCAD 2009
Status: Offline
Direct Link To This Post Topic: Help modeling part
    Posted: 11.May.2015 at 15:50
I'm creating a 3D model of an LMI chemical feed pump. The pump has a fitting on top which has a knob show in the attached photo. The knob has a teardrop shape and curves in two directions. If anyone can help me model this knob or give me some suggestions, I'd appreciate it.
Thanks.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 11.May.2015 at 16:04
You'll need to create the profile of the knob looking at it from the end.  Extrude it.  To get the curved face use the Slice command and an arc (Object or Surface option should work).
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 11.May.2015 at 16:17
Something kind of like this.
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 11.May.2015 at 16:21
Or more like this.
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Using: AutoCAD 2009
Status: Offline
Direct Link To This Post Posted: 11.May.2015 at 16:26
John:
That looks great. I've created the profile and extruded the teardrop shape. The problem I'm having is using the slice command with the arc. When I use the Slice command all it does and slice the teardrop in half. I don't get the contour change that I need.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 11.May.2015 at 16:50
You must have the arc in the wrong position relative to the model.  Change it.
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Using: AutoCAD 2009
Status: Offline
Direct Link To This Post Posted: 11.May.2015 at 17:34
Got it! Thanks so much for all your help!
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,121 seconds.
