RSS discussions
Discussion Discussion forum
Topic ClosedHatch Scale Problem
 Post Reply Post Reply
Author
 Rating: Topic Rating: 1 Votes, Average 5,00  Topic Search Topic Search  Topic Options Topic Options
aqeel222 View Drop Down
Groupie
Groupie
Using: AutoCAD2019
Status: Offline
Direct Link To This Post Topic: Hatch Scale Problem
    Posted: 15.Jun.2015 at 13:53
when i hatch in ground floor any pattern with scale 30 its ok. but when i hatch same pattern in first floor with scale 30 its look too small like solid hatch. how i can resolve this issue.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 15.Jun.2015 at 15:25
Did you try changing the scale of the hatch pattern?
Are these two separate drawings?
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Using: AutoCAD2019
Status: Offline
Direct Link To This Post Posted: 15.Jun.2015 at 15:41
yes both are separate drawings. yes i tried to change the scale. if is in GF 30 then i have to keep in FF 500.. why i cant keep the same scale.. in both dwgs..
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 15.Jun.2015 at 15:55
It's possible someone used an imperial hatch pattern in a drawing that was set up to use metric units.
Open each drawing and type at the command line: MEASUREMENT and compare the resultant values.  They should be the same.
MEASUREMENT=1 uses acadiso.pat  (metric)
MEASUREMENT=0 uses acad.pat   (imperial)
Edited by John Connor - 15.Jun.2015 at 16:59
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Using: AutoCAD2019
Status: Offline
Direct Link To This Post Posted: 16.Jun.2015 at 10:13
thanks. mesurement command solve my problem...
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,150 seconds.
