RSS discussions
Discussion Discussion forum
Topic ClosedPloting Problem
 Post Reply Post Reply
Author
somaya123 View Drop Down
Groupie
Groupie
Using: autocad 2013
Status: Offline
Direct Link To This Post Topic: Ploting Problem
    Posted: 12.Nov.2015 at 10:21
Hello,
I am new to CAD. I got a file with has Xref files and when i tried o plot it to pdf it is only print a very small area.
would someone help?
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 12.Nov.2015 at 11:37
And did you also get copies of the drawings that are being xreffed?
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Using: autocad 2013
Status: Offline
Direct Link To This Post Posted: 12.Nov.2015 at 13:22
yes and all in one file organized in paper space but plot windows or extent and other options did not give the whole drawing.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 12.Nov.2015 at 13:33
What exactly is missing?  Does it have anything to do with the xrefs?
If you are plotting from a layout then you do not want to be plotting using the "Window" or "Extents" option.  You want to be using the "Layout" option.
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Using: autocad 2013
Status: Offline
Direct Link To This Post Posted: 16.Nov.2015 at 14:43
the layout is organized in the paper space for plotting with the title block.
I have tried all options to print the layout, extent and windows but it gave a very small corner of it.
Please let me know If I can send the file in PM as I can not uploaded in puplic.
Thank you
Back to Top
Groupie
Groupie
Using: autocad 2013
Status: Offline
Direct Link To This Post Posted: 25.Nov.2015 at 06:44
I need to share my DOC with anyone can help through PM. Any help ??
Back to Top
Kent Cooper View Drop Down
Senior Member
Senior Member
Using: AutoCAD2020, 2023
Status: Offline
Direct Link To This Post Posted: 25.Nov.2015 at 18:58
There are other variables than just whether you're plotting the layout or the extents.  Could your plotting scale be way off?  In paper space, presumably it should be full size [1:1].
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 2,238 seconds.
