RSS discussions
Discussion Discussion forum
Topic ClosedNeed help!!!! Autocad2015
 Post Reply Post Reply Page  <123
Author
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 04.May.2016 at 14:24
I've used both methods.  It just depends on whether I started a new drawing (Save) or made use of a pre-existing drawing where I do NOT want to overwrite the file (SAVEAS).
What visual style is being used?
Edited by John Connor - 04.May.2016 at 16:27
<<AutoCAD 2015>>
Back to Top
Corpsman8404 View Drop Down
Newbie
Newbie
Using: Autocad 2015
Status: Offline
Direct Link To This Post Posted: 05.May.2016 at 00:36
Did they swith views ie sw view apply then se view apply and close then reopen?
Thats the issue im having I apply the material on different faces in different views and saving each time I make a change, But when I close and save program and reopen it they arent always on all faces. some but not all
Edited by Corpsman8404 - 05.May.2016 at 01:25
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 05.May.2016 at 11:26
I can switch views until the end of time and neither the color nor the material disappears.  Perhaps you have an under-performing graphics card.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: Autocad 2015
Status: Offline
Direct Link To This Post Posted: 05.May.2016 at 14:12
Ok, thank you very much for your help!!!
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 05.May.2016 at 14:20
Upload one of the problematic drawings and I'll take a look at it then tell you what I see or don't see.
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,071 seconds.
