Over 1.120.000 registered users (EN+CZ).
The new Beam calculator, Spirograph generator and Regression curves in the Converters section.
Discussion forum
Post Reply
Page 12> |
| Author | |
petebmor
Newbie
Joined: 21.Jun.2016 Location: United States Using: AutoCadLT2017 Status: Offline Points: 12 |
Topic: Title Block HelpPosted: 21.Jun.2016 at 15:52 |
I just started at a new company and the titleblock that was used by my predecessor is in an odd scale. I tried to rescale it to the correct size and the Attributes becomes unavailable. uploads/658434/24x36_Title_Block.dwg
John Connor
Senior Member
Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 21.Jun.2016 at 17:15 |
What do you want the final size of the title block to be?
Are you going to be plotting from model space? Right now the extents of the drawing are 138'x90' which kind of tells me the company you are working for puts everything in model space including the title block and border which is scaled up to fit the drawing then when it comes time to plot they reverse the process. So, for example, they might plot the drawing at a scale of 1/4"=1'-0". Is that what they do? Edited by John Connor - 21.Jun.2016 at 17:25 |
<<AutoCAD 2015>> |
petebmor
Newbie
Posted: 21.Jun.2016 at 17:24 |
I want to be able to print on 24x36. I am plotting from paper space.
John Connor
Senior Member
Posted: 21.Jun.2016 at 17:28 |
Well for starters then your title block and border belong over in your layout not in model space.
<<AutoCAD 2015>> |
petebmor
Newbie
Posted: 21.Jun.2016 at 17:30 |
If I do that, then the title block is way too small.
John Connor
Senior Member
Posted: 21.Jun.2016 at 17:32 |
That's a minor detail at the moment.
How much space do you want between the edge of the sheet and the rectangular border? Typically we use 5/8" on all four sides. Some companies like to have 1 1/2" on the left side for binding purposes when they have a multiple sheet project. |
<<AutoCAD 2015>> |
petebmor
Newbie
Posted: 21.Jun.2016 at 17:38 |
1 1/2"
John Connor
Senior Member
Posted: 21.Jun.2016 at 17:40 |
Is 5/8" on the other three sides acceptable?
<<AutoCAD 2015>> |
John Connor
Senior Member
Posted: 21.Jun.2016 at 18:13 |
Well I don't have all day. Here is your drawing back. And yes, the attributes are functional.
uploads/165260/24x36_Title_Block_reconfigured.dwg Edited by John Connor - 21.Jun.2016 at 20:16 |
<<AutoCAD 2015>> |
John Connor
Senior Member
Posted: 21.Jun.2016 at 23:11 |
I guess he didn't like my drawing or finally figured out what to do.
Edited by John Connor - 22.Jun.2016 at 11:32 |
<<AutoCAD 2015>> |
Post Reply
Page 12> |
Tweet
This page was generated in 0,076 seconds.
Title Block Help
Topic Options
