RSS discussions
Discussion Discussion forum
Topic ClosedSetup Mulltiple Viewports
 Post Reply Post Reply
Author
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Topic: Setup Mulltiple Viewports
    Posted: 13.Apr.2017 at 14:58
Paper space viewports can be set up using the MVIEW command.  I'd recommend creating a separate layer for your viewports and designate them as "no print" in the Layer Properties Manager.  That way they will appear on your screen yet not be printed.  I would also recommend that once a viewport is set up the way you want that you lock the display so the viewport scale won't be inadvertently changed.
<<AutoCAD 2015>>
Back to Top
Tankman View Drop Down
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 12.Apr.2017 at 22:50
Setup multiple VPORTS years ago. Now can't seem to get it correct.
I only use model space and paperspace.  Cry
Tankman
"When the well's dry, we'll all know the value of water."
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,116 seconds.
