RSS discussions
Discussion Discussion forum
Topic ClosedHELP!! Path Array
 Post Reply Post Reply
Author
Nogsxd View Drop Down
Newbie
Newbie
Using: Cad 2017
Status: Offline
Direct Link To This Post Topic: HELP!! Path Array
    Posted: 23.Mar.2018 at 19:00
Hello.
How can I use path array to follow a radius?
Thanks
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 23.Mar.2018 at 20:33
Hello Nogsxd, you can find your answer in the Related CAD Tip N° 6216, Array along a path.
It will explain the use of the commands DIVIDE or MEASURE.
Then you will be able to place a block copied at egual distances.
Remember the block name or copy/paste it on the command line when you will be invited to choose Block and not point.
There will be also an option to orientate or not the block.
Edited by philippe JOSEPH - 24.Mar.2018 at 07:42
Back to Top
Kent Cooper View Drop Down
Senior Member
Senior Member
Using: AutoCAD2020, 2023
Status: Offline
Direct Link To This Post Posted: 23.Mar.2018 at 22:08
By drawing a path that follows that radius, whether an Arc or a Circle or a Polyline arc segment.  Or am I misunderstanding what you want to do?  An image would help.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,141 seconds.
