RSS discussions
Discussion Discussion forum
Topic ClosedProblems with Copyright
 Post Reply Post Reply
Author
SeanFtS View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Topic: Problems with Copyright
    Posted: 16.Jul.2009 at 05:15
How about raster image.
Plot your drawing into raster image and add it as OLE in dwg, or just send the image to others.
Sean
Back to Top
Kajito View Drop Down
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 15.Jul.2009 at 14:57
why not to use different format? Let say dwf or pdf?
Back to Top
TMcqueen View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 15.Jul.2009 at 09:46
You can also use :
CADLock
AutoCAD OwnerGuard
Back to Top
Vladimir Michl View Drop Down
Senior Member
Senior Member
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 20.Jan.2009 at 21:55
CADVault from CADLock.com can solve most of the copyright/DRM issues in DWG files (including that mentioned above).
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Apeiron View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 20.Jan.2009 at 08:22
and after this operation you can't modify or copy everything in other dwg file?
it's imposible to save like a previous version or like dxf?
it's imposible to export a block?
Edited by Apeiron - 20.Jan.2009 at 14:13
Always is something new to learn ....
for kids :))) http://www.prizee.com/?refer=Apeiron
Back to Top
PaulTaylor View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 20.Jan.2009 at 03:29
I am trying dwglock from dwgsoft.com.
Our department keep the original DWG and send our clients the copies generated the dwglock propram.
Edited by PaulTaylor - 20.Jan.2009 at 03:35
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 19.Jan.2009 at 09:02
I know that is not posible. There is a way to put a password but I think you want an option to not be able to change something.... just to see what you have made.
I'm interesting to this option too but I think there is no option for this.
If you have the option that to not send a dwg file, you can make a pdf but other ways I don't think you have this option.
Back to Top
MaryRoland View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 19.Jan.2009 at 06:11
Is there a way to send a drawing in dwg format where the reciever is unable to make changes to the file. I am having problems with copyright and need to be able to send drawings without the reciever having the ability to change the drawing in any way.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,092 seconds.
