RSS discussions
Discussion Discussion forum
Topic Closedlines not coplanar
 Post Reply Post Reply Page  12>
Author
Armando View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: lines not coplanar
    Posted: 26.Feb.2009 at 20:31
I need help in solving the problem for drawings that have been created with lines that are not coplanar.
How do you make all lines coplanar in the 'Z' axis?
Back to Top
nameci View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 26.Feb.2009 at 20:59
Hey Armando,
You can select all the lines, then go into the properties palette and change the z-values to 0.
Hope that helps,
nameci
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 26.Feb.2009 at 22:28
Hi Nameci,
What you suggested seems logical, but it doesn't seem to allow me to change any line values in the properties chart. All data seems frozen.
Is there a way to unlock the information in the prop menu?
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 26.Feb.2009 at 22:31
I can't change the line values in the properties chart.
All data seems locked in the properties value chart.
Back to Top
msplcdykee69 View Drop Down
Senior Member
Senior Member
Using: Civil 3D, Map, Inventor, Mechanical, & Electrical
Status: Offline
Direct Link To This Post Posted: 26.Feb.2009 at 22:41
make sure when you select the lines that your only trying to change the "Start 'Z' and End 'Z' Values. If that does not work use the PE command (PEDIT) and convert all the lines to Polylines and change the elevation that way.
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 26.Feb.2009 at 23:14
Hi Nameci,
Thanks for your assistance.
It appeaars that the file is staring to respond to the properties pallete reconfiguration for the Z coordinates imput. This is very good.
Unfortunately I had exploded the entire drawing in hopes of being able to move the coordinates easier. Now I must recover the changes or restructure them.
I'll keep you posted on my progress.
Thanks again.
Armando
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 02.Mar.2009 at 04:36
Hi Namici,
I was able to fix the coplanar issue with th elinewoks in my drawing.
Thanks for your clear suggestions.
However, I am having a problem with paper space setup.
I cannot select, delete or expand the outline of defpoint lines in the viewport. How can I fix this problem.
I am also having a problem creating PDF files of the drawing.
I have installed Adobe Acrobat 9 Standard in my computer and the program works fine with all other applications except in ACAD.
I use ACAD 2006.
How can I solve this issues? I am working on a design problem that is due in a month and can't print or create the files needed to submit to my client.
Any suggestions would be truly appreciated.
Thanks,
Armando
Back to Top
rossassociates View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 02.Mar.2009 at 18:33
Armando
Are you saying that if you select a viewport in Layout space, change to Model space and then try to pan or zoom --> scale that you cannot do this?
As for PDF, I would install CutePDF, this is a printer driver which will allow you to create a PDF file, by plotting it and selecting CutePDF..
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 03.Mar.2009 at 00:55
Hey Armando,
If you want, send the file to me and I will look at it and see what I can do. My e-mail is in my profile.
Thanks,
nameci
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 03.Mar.2009 at 05:02
Okay, i'll send it tomorrow.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,930 seconds.
