Over 1.125.000 registered users (EN+CZ).
The new Beam calculator, Spirograph generator and Regression curves in the Converters section.
Discussion forum
Post Reply
| Author | |
onzki
Newbie
Topic: XREF QUESTIONPosted: 24.Jun.2009 at 10:55 |
hi, i used an xref for the title block of my working drawings.. however- when it was opened from a different PC- the xref title block didn't opened automatically- so they need to browse its path again. is there a way to have it automatically opened, as if it is "embeded" or the path is "remembered".. without binding it? thanks!!!
Edited by onzki - 24.Jun.2009 at 10:57 |
Apeiron
Groupie
Joined: 30.Aug.2007 Location: Romania Status: Offline Points: 74 |
Posted: 24.Jun.2009 at 12:50 |
Hello
when you give the file and you want to have the xref together it's a better ideea to make e-Transmit from autocad. e-Transmit it's a function that is collecting everything you have outside of the master drawing (pictures xref's included ) and it's making a zip file with everything inside. Now.... if you give this zip fiel to another one to work it's everything inside. The second option is to put the xref's in a server and evertybody is making the same and in this way everytime the dwg file is searching the xrefs in a place from server.... Fell free to choose the way ....... good luck |
Always is something new to learn ....
for kids :))) http://www.prizee.com/?refer=Apeiron |
Post Reply
Tweet
This page was generated in 0,086 seconds.
XREF QUESTION
Topic Options
