RSS discussions
Discussion Discussion forum
Topic Closedstudent needs help
 Post Reply Post Reply
Author
hazetroy View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: student needs help
    Posted: 23.Jul.2009 at 00:26
i am a drafting studend and recently got auto cad mechanical 2010  i need to know how to save my drawings as older versions of autocad so my master cam x3 can read them thanks for any help
Back to Top
nameci View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 23.Jul.2009 at 02:13
Hi hazetroy,
When you save an AutoCAD file, at the bottom of the save screen it will say what you are saving the file as (AutoCAD 2007) for example. Just click on the arrow on the right side and it will bring up a list of different file types and versions you can save your file as. Select the one you want and that should do it.
I hope that helps,
nameci
Back to Top
Vladimir Michl View Drop Down
Senior Member
Senior Member
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 23.Jul.2009 at 07:51
If you are saving for older version of Mechanical (not plain AutoCAD), make sure you use the "mechanical" format - see the tip:
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 5,918 seconds.
