Discussion forum
Post Reply
Page 12> |
| Author | |
DomS1
Newbie
Joined: 02.Jun.2008 Location: United Kingdom Status: Offline Points: 7 |
Topic: Error opening drawingPosted: 12.Jun.2009 at 12:38 |
We have one user on our system that can't open drawing files every other user can. Whenever he opens a set of drawings, he gets a message "fatal error, unhandled violation access...". Does anyone know what this could be as every other user can open these files with no problems. He is running vista & has tried to open the files in AutoCAD 2009 & 2010 & the drawings are saved at format 2000.
Kajito
Senior Member
Joined: 29.Oct.2008 Location: Ireland Status: Offline Points: 130 |
Posted: 12.Jun.2009 at 16:26 |
Hi,
we had similar issue in our office few months ago. As I had no time looking for cause, I unistalled Autocad and cleaned all the files associated with it (including regiter) and installed it back again. It's been working since. Dont forget to install all the patches and updates for ur Autocad from autodesks website. regards Karol |
Ringis
Groupie
Joined: 08.May.2008 Location: Sweden Status: Offline Points: 26 |
Posted: 15.Jun.2009 at 11:04 |
Hi! Your error message contains alot of number as well, they are for a reason, if you want us to help , please type all numbers in your error message! //Tobias
SeanFtS
Groupie
Posted: 15.Jun.2009 at 15:51 |
If this is the only AutoCAD installed on 1. Go to "Control Panel > User Accounts and Family Safety > User Accounts";
2. Find "Turn User Account Control On or off" and turn off the user account control. After the UAC is disabled, try to open your drawing and see if there is still the same error message. I'm not sure if this works but it worth a try. Sean
Edited by SeanFtS - 15.Jun.2009 at 15:59 |
gcurtis2
Newbie
Joined: 03.Aug.2009 Location: United States Status: Offline Points: 4 |
Posted: 03.Aug.2009 at 16:57 |
hey sean ...i have the same issue..i did shut off uac...i am using a plug in of LDassistant that is a lighting design program..it uses DLL features and that is my fatal error...unhandled access violation writing 0x00070 exception at 635dc655h.
Any clues...it craches every time I try top acces the content block that I need to use the program..
SeanFtS
Groupie
Posted: 04.Aug.2009 at 03:02 |
If you unload the DLL in AutoCAD, does it still report error? If it stops crashes, it is the compatible issue with the Dll and AutoCAD, contact LDassistant and call for compatible package.
Sean
gcurtis2
Newbie
Posted: 04.Aug.2009 at 05:10 |
i will need a little help on the unload dll..contact me at gcurtisld@gmail.com if you can talk me thru that..
SeanFtS
Groupie
Posted: 04.Aug.2009 at 09:38 |
Command: Menuload
Can you find the corresponding item(LDassistant) in it? If there it is, click "unload".
Sean
gcurtis2
Newbie
Posted: 20.Aug.2009 at 04:52 |
yeah Sean it still crashes..I have been using the program for over a year and it just started doing it..i had other issues with my virus protection NOD32 but I uninstalled that and reinstalled both programs with same results...Rufus with LDAssistant has been on my computer for hours trying to figure it out..no luck....In lost on this one..
Gary
gcurtis2
Newbie
Posted: 28.Aug.2009 at 16:12 |
can you give me a better detail of cleaning all files associated, and what in the registry I have to deletse also?
Post Reply
Page 12> |
Tweet
This page was generated in 0,230 seconds.
Topic Options
