RSS discussions
Discussion Discussion forum
Topic ClosedError opening drawing
 Post Reply Post Reply Page  12>
Author
Kajito View Drop Down
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Topic: Error opening drawing
    Posted: 28.Aug.2009 at 16:22
- uninstall Autocad
- delete everyting within "c:\Documents and Settings\(name)\Application Data\Autodesk\AutoCAD 2006\"
- as well delete "c:\Documents and Settings\Karol.HRA\Local Settings\Application Data\Autodesk\AutoCAD 2006\"
- in case the folder in "c:\Program Files\AutoCAD 2006\" was not deleted at uninstall process, delete it
- go to start/run, type regedit. Go to hkey_local_machine/software and delete Autodesk. If you wish you can create backup of your registry (just in case)
- restart PC, install Autocad
it did work for me
Back to Top
gcurtis2 View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 28.Aug.2009 at 16:12
can you give me a better detail of cleaning all files associated, and what in the registry I have to deletse also?
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 20.Aug.2009 at 04:52
yeah Sean it still crashes..I have been using the program for over a year and it just started doing it..i had other issues with my virus protection NOD32 but I uninstalled that and reinstalled both programs with same results...Rufus with LDAssistant has been on my computer for hours trying to figure it out..no luck....In lost on this one..
Gary
Back to Top
SeanFtS View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 04.Aug.2009 at 09:38
Command: Menuload
Can you find the corresponding item(LDassistant) in it? If there it is, click "unload".
Sean
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 04.Aug.2009 at 05:10
i will need a little help on the unload dll..contact me at gcurtisld@gmail.com if you can talk me thru that..
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 04.Aug.2009 at 03:02
If you unload the DLL in AutoCAD, does it still report error? If it stops crashes, it is the compatible issue with the Dll and AutoCAD, contact LDassistant and call for compatible package.
Sean
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 03.Aug.2009 at 16:57
hey sean ...i have the same issue..i did shut off uac...i am using a plug in of LDassistant that is a lighting design program..it uses DLL features and that is my fatal error...unhandled access violation writing 0x00070 exception at 635dc655h.
Any clues...it craches every time I try top acces the content block that I need to use the program..
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 15.Jun.2009 at 15:51
If this is the only AutoCAD installed on Vista, there may be something to do with Vista User Accounts Control, I think you may be interested in trying this and decide if to re-install AutoCAD.
1. Go to "Control Panel > User Accounts and Family Safety > User Accounts";
2. Find "Turn User Account Control On or off" and turn off the user account control.
After the UAC is disabled, try to open your drawing and see if there is still the same error message.
I'm not sure if this works but it worth a try.
Sean
Edited by SeanFtS - 15.Jun.2009 at 15:59
Back to Top
Ringis View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 15.Jun.2009 at 11:04
Hi!
Your error message contains alot of number as well, they are for a reason, if you want us to help , please type all numbers in your error message!
//Tobias
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 12.Jun.2009 at 16:26
Hi,
we had similar issue in our office few months ago. As I had no time looking for cause, I unistalled Autocad and cleaned all the files associated with it (including regiter) and installed it back again. It's been working since. Dont forget to install all the patches and updates for ur Autocad from autodesks website.
regards
Karol
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,117 seconds.
