RSS discussions
Discussion Discussion forum
Topic Closedproblem with spline
 Post Reply Post Reply
Author
krish_architect View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: problem with spline
    Posted: 23.Oct.2009 at 03:17
dear carl B
me too new in here...... so.. its okk tht still you have given me a solution..... thanx a lot..... but i dont hv any website like tht....its okk so far..... lets see how can i manage....... thnx again for your solution...keep in touch.....Thumbs%20Up
- krish...Smile
Back to Top
CarlB View Drop Down
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 21.Oct.2009 at 06:41
I'm new to this forum-so I looked at options for replying.  All I see is the option to  attach images, and images must first be posted at a hosting/public website.  Maybe there is a description under "forum rules"..?
You should be able to join semi-circles by moving one so endpoints connect, convert to polylines with "pedit", then "join". Filleting may be a problem depending on fillet radius and where you select the arcs.
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 21.Oct.2009 at 04:43
thnx a lot evrybody....i have tried 'flatten' nd it worked.....
dear carl B,
in my first post i'hv asked abt the attachments...as i'm short of words to describe  at what situation i'm filleting the arcs ......... actually its happenig but nt in my desired way thats why i'hv asked......
any way can u tell me how can I attach my screen shot.... it will be much more easier fr u to undrstand.......even i can attach my .dwg file.....but how???
thanx....
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 16.Oct.2009 at 20:12
Originally posted by zarzar zarzar wrote:
how can i change the spline to plyline?
As I mentioned, you can also do it using the command "flatten".
Back to Top
Arben.Allaraj View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2008
Status: Offline
Direct Link To This Post Posted: 16.Oct.2009 at 11:04
You need appload the file SPL2PL.VLX from dotsoft.com.
SPL2PL.VLX - This is a free tool from dotsoft.com. After you download it, drag and drop the .VLX file into the AutoCAD editor, then run the command SPL2PL. This tool will create a POLYLINE or LWPOLYLINE depending on the setting of the system variable PLINETYPE
Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com
Back to Top
zarzar View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 16.Oct.2009 at 06:39
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 16.Oct.2009 at 02:27
Fillet of splines not allowed by AutoCAD
you can convert splines to polylines, then pedit, fillet, etc.
One way to convert them is with the "flatten" (Express Tools) command.
Don't know why you can't fillet between semi-circles, are they "arc" objects? What does AutoCAD report when you try to fillet or join them?
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 26.Sep.2009 at 13:26
dear friends,
I'm having real problem while filleting the spline with a simple st line........... it's not happenning.....and in the other hand when I am filleting/joining two opposite facing semi circle still it's not working......
Is it due to my fault or it's not allowed by Auto CAD?
I can send my faulty cad file (.dwg)
Even I have the screen shot image.....but how can I attach?
I think those things can make you sure what I am talking about.....
I'm in fix...plz reply....
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,977 seconds.
