Over 1.132.000 registered users (EN+CZ).
Discussion forum
Post Reply
| Author | |
5han3
Newbie
Joined: 13.Nov.2007 Location: United Kingdom Status: Offline Points: 10 |
Topic: zooming problemPosted: 14.Jan.2008 at 16:13 |
hey can anyone help
i dont no what, but i have done something to model when we insert a new plan in. when doing zoom then either all or Extent, the picture gets really small and goes to the left corner, now it should expand to the plan ful size to screen, i have tryed to look for anything else on the page but i cant see anything, can anyone help to fix?? Edited by 5han3 - 14.Jan.2008 at 16:14 |
Belianis
Newbie
Joined: 14.Jan.2008 Location: Poland Status: Offline Points: 3 |
Posted: 14.Jan.2008 at 22:32 |
I've had similar problem, everytime I've switched between layout and model or different viewports, modelspace view was regenerated and everything got small (just like I was using ZOOM all). In my case setting UCSFOLLOW to 0 solved the problem.
http://www.cadaplus.com - AutoCAD plugin for architects with over 500 new commands ... and some free blocks :)
Rman
Groupie
Posted: 15.Jan.2008 at 09:22 |
Have you check with Layer Manager to see wether any layers has been turn off?
5han3
Newbie
Posted: 15.Jan.2008 at 14:28 |
erm yes i have checked the layers and there all on and set the UCSFOLLOW to 0. the problem is when i paste the plan into the drawing anywhere and do zoom all or extent it will zoom in on the plan, but if i paste the plan at 0,0 and zoom it gets smaller??? the problem is i need to paste it at 0,0
Breeze104
Senior Member
Joined: 03.Aug.2007 Location: United States Using: Production Design Suite Premium 2015 Status: Offline Points: 125 |
Posted: 15.Jan.2008 at 14:45 |
Have you tried to paste it @ a different location and then move it to 0,0?
Also, you might have something hanging out of normal view. After you have zoomed to extents try to zoom a bit further out and then try erasing all around the outside of the plan you might find that there is actually someting out there causing the problem. Edited by Breeze104 - 15.Jan.2008 at 14:51 |
Breeze |
Rman
Groupie
Posted: 16.Jan.2008 at 01:37 |
You said you want to insert a new plan into a drawing, are there any entities in the drawing before you do inserting? If the answer is yes, you need to make sure the location\coordination (x,y) between both of them when inserting. Possibly the location between them is too far away, so their view become to small because AutoCAD interface want to show us whatever entities within the drawing.
Or, alternatively, try insert your new plan into a new drawing. Let see what will happened.
5han3
Newbie
Posted: 28.Jan.2008 at 14:05 |
i have tryied to delete everything by zoomin out but it doesnt seem to pick anything up, and yes it is only the plan is inserted into.
Arben.Allaraj
Senior Member
Joined: 14.Nov.2007 Location: Albania Using: AutoCAD 2008 Status: Offline Points: 602 |
Posted: 29.Jan.2008 at 14:19 |
Check the ZOOMFACTOR VARIABLE.
Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com |
5han3
Newbie
Posted: 29.Jan.2008 at 16:04 |
whats the default?? |
Arben.Allaraj
Senior Member
Posted: 29.Jan.2008 at 16:11 |
Ing Arben.Allaraj
Post Reply
Tweet
This page was generated in 0,156 seconds.
zooming problem
Topic Options
5han3 wrote:
