RSS discussions
Discussion Discussion forum
Topic ClosedLaser Engraving
 Post Reply Post Reply
Author
JRingo83 View Drop Down
Newbie
Newbie
Using: 2016 LT
Status: Offline
Direct Link To This Post Topic: Laser Engraving
    Posted: 08.Mar.2018 at 14:58
Hi,
I'm having an issue drawing in CAD 2016 LT. I'm using the files to print on a laser engraver. As you can see in the pictures I cant print a perfect circle as its printing "low vector" files. Is there a setting in CAD to fix this? The software I'm using to print is CorelDraw. Thanks.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 08.Mar.2018 at 16:55
Did you utilize a DXF file from AutoCAD then opened in CorelDraw?
Edited by John Connor - 08.Mar.2018 at 16:56
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: 2016 LT
Status: Offline
Direct Link To This Post Posted: 08.Mar.2018 at 16:57
Yes, I exported as a DXF file to import into CorelDraw.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 08.Mar.2018 at 17:30
Have you seen this?
https://community.coreldraw.com/talk/coreldraw_graphics_suite_x5/f/coreldraw-x5/24697/beginners-question-smoothing-lines-for-laser-cutting
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: 2016 LT
Status: Offline
Direct Link To This Post Posted: 08.Mar.2018 at 17:32
I will read the information there, it seems as its the same problem. Thanks so much!
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,092 seconds.
