Over 1.114.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
VermaBhola123
Newbie
Joined: 02.Aug.2020 Location: Canada Using: AutoCAD2018, LT, Revit 2028 Status: Offline Points: 4 |
Topic: Dynamic BlockPosted: 02.Aug.2020 at 03:54 |
I downloaded steel angle shape dynamic block from CADForam. This downloaded block is opening only as polyline not as dynamic block. Any help appreciated.
I am using AutoCAD LT 2020.
John Connor
Senior Member
Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 02.Aug.2020 at 13:17 |
There are several steel angle shape dynamic blocks available in the CAD/BIM section of the CADForum. Which one specifically did you download?
<<AutoCAD 2015>> |
VermaBhola123
Newbie
Posted: 02.Aug.2020 at 14:57 |
eL-Shape profile - dynamic block, large cat: Steel DWG2018 Downloaded: 24x Size 117,9kB • from 25.7.2020 Uploader: VladimĂr Michl • Author: Brian Shutts
philippe JOSEPH
Senior Member
Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1521 |
Posted: 02.Aug.2020 at 20:09 |
Dynamic blocks are not available on the LT releases.
If you have a friend with a plain release ask him to insert each visiblity of each blocks in a file so that you can have access. If you want some angles there should be everything in the CAD/BIM Blocks library. Try the last uploaded AutoCAD file : AMSTLSHAP2D.dwg.
Edited by philippe JOSEPH - 02.Aug.2020 at 20:27 |
philippe JOSEPH
Senior Member
Posted: 02.Aug.2020 at 21:53 |
John Connor
Senior Member
Posted: 03.Aug.2020 at 11:35 |
Sorry, but I beg to differ with you Philippe. Dynamic Blocks were fully incorporated into AutoCAD LT in the 2007 release. This information comes from Kate Morrical, Technical Marketing Directory for AutoDesk and recognized expert in all things related to AutoDesk LT (2/10/2012).
<<AutoCAD 2015>> |
philippe JOSEPH
Senior Member
Posted: 03.Aug.2020 at 12:54 |
John, I hope this is OK for VermaBhola123 but It seems to me that I had to do "special" files for co worker without plain releases in 2008 but was it whith the AutoCAD 2008 or older 2006 ?
I hope VermaBhola123 is inserting the file before and not trying to copy/paste it.
Edited by philippe JOSEPH - 03.Aug.2020 at 12:54 |
John Connor
Senior Member
Posted: 03.Aug.2020 at 16:07 |
Fully functional in the 2007 release of AutoCAD LT. In the 2006 release of LT they could be manipulated but you could not create or edit one.
<<AutoCAD 2015>> |
philippe JOSEPH
Senior Member
Posted: 03.Aug.2020 at 17:14 |
OK John, then it could be that the OP wants to open the dynamic file ( no dynamic bloc editor available because of the LT ), copy and the paste the result into his own file instead of INSERT the dynamic file and have access to the various visibilities.....
Edited by philippe JOSEPH - 03.Aug.2020 at 17:15 |
VermaBhola123
Newbie
Posted: 03.Aug.2020 at 20:41 |
Thanks Phillipe & John for the help. Actually John is right. I am able to work with another dynamic block "steel joists" in LT. It works fine. And yes, I was copying and pasting. By inserting my dynamic block angle shape is also working fine. So, thanks again.
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,102 seconds.
![CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz] CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz]](/common/arkance_186.png)
Dynamic Block
Topic Options
