RSS discussions
Discussion Discussion forum
Topic ClosedVBA Coding
 Post Reply Post Reply Page  12>
Author
GaryM View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: VBA Coding
    Posted: 20.Aug.2007 at 10:23
Hi
Looking for help on adding current layer names in you active drawings to a  combo box?
Let me explain what i would like to do.
I designed a userform wich includes your basic layer operations turning ON & OFF, FREEZING, THAW etc, but know i would like to add a another function where you can delete a layer, but when you click the delete button it opens another userform where you can either pick a layer using a command button or select a layer in a combo box.
Know the question how would i code the form or combo box to go search for current layers in active drawing and list it in the combo box index.
I'm kinda rusty on my vba coding so any kind of help would be appreciated.
CheersConfused
Edited by GaryM - 22.Aug.2007 at 15:58
Regards,
Gary Mansfield
Back to Top
Vladimir Michl View Drop Down
Senior Member
Senior Member
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 24.Aug.2007 at 22:21
You can look at the ThisDrawing.Layers collection and iterate through it.
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 28.Aug.2007 at 10:33
Thanks for the suggestion, but came right doing it another way... check it out!
Private Sub UserForm_Activate()
  Dim objLayers As AcadLayers
  Dim objLayer As AcadLayer
'search for layers in current drawing and add to combo box
For Each objLayer In ThisDrawing.Layers
  frmDelLayer.cboLayerName.AddItem (objLayer.Name)
  Next
End Sub
Regards,
Gary Mansfield
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 28.Aug.2007 at 12:07
Yes, this is the ThisDrawing.Layers iteration :-)
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 28.Aug.2007 at 13:21
HI
Now i'm struggling to delete a layer. How would i go about this...
Here is the code i'm using. What i'm actually trying to do is that i want to select from the combo box a layer to delete.
Here is the code i'm using;
Private Sub cmdOk_Click()
On Error Resume Next
  Dim strLayerName As String
  strLayerName = frmDelLayer.cboLayerName.Text
  Set objLayer = ThisDrawing.Layers(strLayerName)
    If objLayer Is Nothing Then
      MsgBox "Layer " & strLayerName & " not found"
      Exit Sub
    End If
  objLayer.Delete
    If Err Then
      MsgBox "Unable to delete layer: " & vbCr & Err.Description
    Else
      MsgBox "Layer '" & strLayerName & "' deleted"
    End If
  End Sub
Giving me a error: "Object is referenced by other object(s)"
Any ideas on what i'm doing wrong.
Regards,
Gary Mansfield
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 28.Aug.2007 at 13:27
The layer your are trying to delete is probably not empty (contains entities, is referenced from a block, etc.). You can only delete empty layers in this way.
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 28.Aug.2007 at 13:39
Smile cool you are quite right.
Autocad gives you the LAYDEL command where you can delete layers with all entities etc. Is there anything similar i could do with vba?
Regards,
Gary Mansfield
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 28.Aug.2007 at 13:47
You can either write the code to remove all possible references to this layer or you can run LAYDEL from VBA (through SendCommand).
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 28.Aug.2007 at 14:16
How would i write the code to remove all possible references.
And the Sendcommand "LAYDEL" just activates the command does not actually delete the layer,  you still l need to do the normal steps after the laydel command is entered.
I want to delete from my delete layer form after selecting the layer from the combo box and clicking ok.
Regards,
Gary Mansfield
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 28.Aug.2007 at 14:28
The code would be quite complex - it would need to go through nested blocks, xrefs, etc.
Try to use LAYDEL - with all following options on the commandline - e.g.:
-LAYDEL Name mylayer
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,199 seconds.
