RSS discussions
Discussion Discussion forum
Topic ClosedA FATAL ERROR
 Post Reply Post Reply Page  12>
Author
jdycady View Drop Down
Newbie
Newbie
Using: autocad 2011
Status: Offline
Direct Link To This Post Topic: A FATAL ERROR
    Posted: 05.Sep.2011 at 21:58
I finished my solid drawing. I went to Layout1 and did SOLVIEW and brought in the TOP,FRONT,SIDE and then the ISO. As I brought in the views I noticed the viewports didn't look right, only half of the drawings were in the viewports. Usually when something like this happens I go back into Model and back in to Layout1 and the vp's look right.  This time when I tried to go back out and in again I received a fatal error and cad shut down. I open AutoCad again, recovered my drawing and then the same thing happened again. I tried opening another file and the same thing happened again. I sent in Error reports but haven't received and response. The latest product update are current. This morning I opened Acad again and experimented on the drawing that opens up in the begining. I drew a solid, then put it in the layout1 using Solview and the same thing happened again. Its defenitely a software issue I would think. What do you think?   Thank You.    RockyRoad
Johnny Y
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 06.Sep.2011 at 00:08
You might try running the REPAIR option.
<<AutoCAD 2015>>
Back to Top
FarooqiSA View Drop Down
Groupie
Groupie
Using: AutoCAD2007, 2008, 2011
Status: Offline
Direct Link To This Post Posted: 06.Sep.2011 at 06:14
If you are having the same problem with each and every drawing, then probably your software is corrupt and you need to reinstall it. But if it only happens with one drawing, then that particular file is corrupt.
Back to Top
Newbie
Newbie
Using: autocad 2011
Status: Offline
Direct Link To This Post Posted: 06.Sep.2011 at 06:35
I opened autocad pressed f1 and searched for the Repair option. It give instructions for windows xp and windows vista, but nothing for windows7 which is what I have. Do you know where to look for the Repair option for windows7.  Thank You   RockyRoad
Johnny Y
Back to Top
Newbie
Newbie
Using: autocad 2011
Status: Offline
Direct Link To This Post Posted: 06.Sep.2011 at 06:37
What do you think would happen if I tried to open the file on the schools computer?
Johnny Y
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 06.Sep.2011 at 11:26
If you have an option opening it on schools computer, go for it and see how it behaves. If the same thing happens, there is something wrong with the file for sure. And if it works perfect, you need to reinstall your software.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 06.Sep.2011 at 12:04
Never uninstall/reinstall software BEFORE trying the REPAIR option.  It will be found in the Add/Remove Software area of Windows.
If you do have to uninstall/reinstall AutoCAD there is a set procedure that AutoDesk recommends you follow to ensure a clean uninstall.  If you don't follow the procedure your reinstall will probably fail to fix the problem.
I agree that you should first try to open the drawing on one of the school's computers.
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 06.Sep.2011 at 12:06
How to uninstall or change (Repair) a program in Windows 7.
http://windows.microsoft.com/en-US/windows7/Uninstall-or-change-a-program
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 06.Sep.2011 at 12:09
How to remove ALL AutoCAD products from a system.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240697
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: autocad 2011
Status: Offline
Direct Link To This Post Posted: 06.Sep.2011 at 15:19
Thank You for repling to my post. Its in the early AM where I'm at, and I on my way to school to see what happens. I'll let you know. I appreciate you.  Thank You   RockyRoad
Johnny Y
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,066 seconds.
