RSS discussions
Discussion Discussion forum
Topic Closedcan't explode block
 Post Reply Post Reply Page  12>
Author
arniedegz24 View Drop Down
Newbie
Newbie
Using: ACAD 2013
Status: Offline
Direct Link To This Post Topic: can't explode block
    Posted: 23.Dec.2012 at 08:58
Hi Philppe,
I hope I am not late. If you are trying to copy something inside a block by using the hot keys(or keyboard command ctrl_c), well you can't. what you have to do is copy the object by typing copy or c then enter, click base point then click anywhere you can put it (which is visible of course). then select the copied object and then type in the command line REFSET then click remove, now it will be taken out of the block and placed onto you model layout. Taddahh!!! you've copied the thing!!!
Ciao!!!
Arnie
Never underestimate, always have a spare!!! :)
Rock On!
Back to Top
nickske8x View Drop Down
Newbie
Newbie
Using: Autocad 2010
Status: Offline
Direct Link To This Post Posted: 21.Dec.2012 at 15:18
if i understand your question/remark good you mean that in refedit you can't do anything whit it.
As i know (i'm just a amateur) refedit and block editor are 2 different things.
If you set the block in block editor and do as i said last time it works Wink
Back to Top
philippe JOSEPH View Drop Down
Senior Member
Senior Member
Using: AutoCAD Mechanical 2017
Status: Offline
Direct Link To This Post Posted: 21.Dec.2012 at 15:06
Hello N° 3 nickske8x, you are happy to do this because in my block editor ( REFEDIT ) I have a message that says : the command COPYCLIP is not accessible .
Back to Top
Newbie
Newbie
Using: Autocad 2010
Status: Offline
Direct Link To This Post Posted: 21.Dec.2012 at 12:37
Finally got something that works, and its very easy
First select the block and go to block editor.
Than copy the block in block editor and paste it on a other acad sheet.
After this you can select al lines separately
Edited by nickske8x - 21.Dec.2012 at 14:10
Back to Top
ABUSAIF View Drop Down
Groupie
Groupie
Using: Autocad 2013
Status: Offline
Direct Link To This Post Posted: 20.Dec.2012 at 15:27
Hello nickske8x, will you be able to attach the block,I had this issue before, copy the block and insert it in a new drawing, check explode box when inserting the block.
good luck..
Dead
Back to Top
Newbie
Newbie
Using: Autocad 2010
Status: Offline
Direct Link To This Post Posted: 20.Dec.2012 at 15:14
oh i was to quick to celebrate.
i'm now in reference edit and can't save the file.
In fact i can't do anything with it so i type refclose and yes its a block again..Angry
you can see that i'm new with autocad i think haha.
hope someone can give me a solution.
And Philippe Joseph thank you for your help so far!
Edited by nickske8x - 20.Dec.2012 at 15:19
Back to Top
Newbie
Newbie
Using: Autocad 2010
Status: Offline
Direct Link To This Post Posted: 20.Dec.2012 at 14:59
thanks for the help everyone.
I finally found a solution, now i can select al the lines separately.
This is how i done it:
I double clicked on the block than the screen reference edit came up i choose settings and saw that lock object not in working set was on.
Turned that of and now i can do everything with the drawing.
maybe its not the right way to do it?
but i'm happy i can finally use parts of the drawing
greetings nick Big%20smile
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 20.Dec.2012 at 14:42
Hello N° 2 nickske8x, I took a look at your problem and it looks like that a block made with unexplodable option can't be exploded even with EXPLMODE = 1.
I haven't find the solution in the TIP 4023.
It's still possible to copy each line, arc, etc of the unexplodable block with the command NCOPY but it's exhausting because you just can select the objects one by one.
On the other hand, if these blocks were made unexploable it's maybe for a good reason.
But you can modify them with the command REFEDIT (  you "enter" in the block without exploding it and modify it like you want ), and it's maybe your solution.
Back to Top
Newbie
Newbie
Using: Autocad 2010
Status: Offline
Direct Link To This Post Posted: 20.Dec.2012 at 14:01
hello philippe joseph,
i have problem to explode other persons blocks.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 20.Dec.2012 at 12:37
If it is an anonymous block it can be exploded using the lisp routine, found in the link below, by Lee Mac (post #5) that uses defun c:ExplAnon to invoke the program.
http://www.theswamp.org/index.php?topic=37245.0
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,104 seconds.
