Over 1.122.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
Page 12> |
| Author | |
Eldorado
Newbie
Joined: 14.Jul.2011 Location: United Kingdom Using: Autocad 2010 Status: Offline Points: 13 |
Topic: 3D HandrailPosted: 23.Jan.2014 at 15:48 |
Hello everyone. I have a problem with creating a handrail in 3d for stairs, if you take a look to my drawing attached to this post.I need to divide that red part of handrail in two equal parts and adjust by ucs that i could to print them out in 2D like this ( please see the picture in 2d view).uploads/204404/Plot.pdfI would appreciate any help.Thank you for your time.uploads/204404/Stairpro.dwg
John Connor
Senior Member
Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 23.Jan.2014 at 18:17 |
Eldorado: I don't know if you realize it or not but your drawing is based on a template that uses IMPERIAL units. In this case they happen to be DECIMAL inches. Given that your location is listed as the United Kingdom wouldn't you rather be drawing using a template based on METRIC units?
Your stringer actual measures 40 INCHES wide not 40 MILLIMETERS. Same thing goes for your riser height which you show as 179. It is in inches not millimeters. BTW...40mm = 1.57 inches which is pretty close to the what it would be in the U.S. 170mm = 7.05 inches. Edited by John Connor - 23.Jan.2014 at 18:22 |
<<AutoCAD 2015>> |
Eldorado
Newbie
Posted: 23.Jan.2014 at 19:52 |
Yes, I did,t know about it but this is not an orginal file, I have copied from original file which is in decimal. Thank you for note
John Connor
Senior Member
Posted: 23.Jan.2014 at 20:30 |
OK...you know. Are you going to do anything about it?
Do you know how to extract the 2D views from the 3D model? |
<<AutoCAD 2015>> |
Eldorado
Newbie
Posted: 23.Jan.2014 at 20:51 |
Yes I know but in this case is more complicated. I think about how to set the coordinate system usc that I could extract 2D .If there would be a two arcs instead helix ,would be no problem.
John Connor
Senior Member
Posted: 24.Jan.2014 at 00:11 |
What command will you be using to extract the 2D views? It may not make that much of a difference what your UCS is set to.
<<AutoCAD 2015>> |
Eldorado
Newbie
Posted: 24.Jan.2014 at 10:11 |
using SOLVIEW and SOLDRAW but have no idea for now how to set the USC in the irregular space with that helix .
John Connor
Senior Member
Posted: 24.Jan.2014 at 13:26 |
Set it for a plan view then derive the other views from it.
<<AutoCAD 2015>> |
Eldorado
Newbie
Posted: 24.Jan.2014 at 13:57 |
I have done but unfortunately is not accurate design. I have done with arcs as i said before and adjusted the ucs.There is a file uploads/204404/StairproHan...dwg
Eldorado
Newbie
Posted: 24.Jan.2014 at 13:59 |
Do you mean in the paper space?
Post Reply
Page 12> |
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,166 seconds.
3D Handrail
Topic Options
