Please abide by the
rules of this forum.
| Author |
Topic Search Topic Options
philippe JOSEPH
Senior Member
Using: AutoCAD Mechanical 2017
Status: Offline
Posted: 08.Oct.2013 at 13:16 |
Seant, thanks a lot for your informations.
I will go on the site that you are talking about.
Again, thanks for all.
mmaurigi
Groupie
Using: AutoCAD 2009
Status: Offline
Posted: 08.Oct.2013 at 15:05 |
I was referring to your post Seant. If you can update it for 2013 or 2009, that would be perfect. I can wait if it takes a week.
Thanks
SEANT wrote:
I think the "app" reference pertains to the one I alluded to in my post. Unfortunately, The compatibility of the routine is only AutoCAD 2011 - 2012. If needed, I'll try to update to 2013 - 2014, but it wouldn't be available until later this week. In the mean time, this link has some discussion on the matter as well as hosting my current routine and a lisp variant by Marko Ribar. See Reply 14.
SEANT
Groupie
Using: AutoCAD 2016
Status: Offline
Posted: 08.Oct.2013 at 23:08 |
Here is an updated to work with 2013-2014. Place “Ellipsoid.dll” on your hard drive. In AutoCAD, invoke the NETLOAD command and
retrieve that file. If you are using
AutoCAD 2014 a warning will be shown if you have not saved it in a Trusted
Files Location, but the warning box does give you the option of loading anyway.
For sure, the routine qualifies as rudimentary. The command can be called via ELLIPSOIDSOLID
or ELSOL for short. The prompt asks for
a Length, Width, and Height. An
ellipsoid of the input dimensions is centered at the WCS origin with the axis
aligned to the X, Y, and Z.
Edited by Vladimir Michl - 18.Oct.2013 at 14:05
mmaurigi
Groupie
Using: AutoCAD 2009
Status: Offline
Posted: 09.Oct.2013 at 15:14 |
Thanks very much for updating the file. There is a problem though.
I load the file with NETLOAD, then at the command prompt, I type ELSOL. The prompts come up asking for the Length, Width, and Height. After entering those values, I get a Fatal Error and get kicked out of AutoCAD.
SEANT wrote:
Here is an updated to work with 2013-2014. Place “Ellipsoid.dll” on your hard drive. In AutoCAD, invoke the NETLOAD command and retrieve that file. If you are using AutoCAD 2014 a warning will be shown if you have not saved it in a Trusted Files Location, but the warning box does give you the option of loading anyway.
For sure, the routine qualifies as rudimentary. The command can be called via ELLIPSOIDSOLID or ELSOL for short. The prompt asks for a Length, Width, and Height. An ellipsoid of the input dimensions is centered at the WCS origin with the axis aligned to the X, Y, and Z.
uploads/244286/Ellipsoid.zip
John Connor
Senior Member
Using: AutoCAD 2018
Status: Offline
Posted: 09.Oct.2013 at 16:50 |
I tried it using 2014 and I also received the Fatal Error: Unhandled
Access Violation message then closing the window AutoCAD crashed. Is there something a user must do before
invoking the command?
<<AutoCAD 2015>>
Kent Cooper
Senior Member
Using: AutoCAD2020, 2023
Status: Offline
Posted: 09.Oct.2013 at 18:00 |
Here's a routine that makes one as a Solid [actually a segmented approximation to whatever level of precision the User chooses]. See comments at the top. (It's really fun to watch it do its thing!) With high precision [I've tried it with precision as high as 200], you'll have to give it time to do the Intersect operation at the end. It doesn't yet have all the usual bells and whistles, but I'm working on incorporating those, as well as having it build it where the User designates instead of at the WCS origin, using true Ellipsoids of rotation when any axes are equal, etc.
;; EllipticalDomeSolid.lsp [command name: EDS] ;; To construct a Dome shape in Elliptical form, as a 3D Solid. ;; User specifies Axis lengths, height and precision level. ;; Constructs with base centered at WCS origin. ;; To make a hollow dome, construct one to outer dimensions ;; and another to inner dimensions, and Subtract. ;; Note that mid-line of each "wedge" surface traces along "true" ;; dome surface, and "corners" between "wedges" are slightly ;; outboard of true surface [less so with greater precision]. ;; However, base perimeter is truly Elliptical, with transitional ;; triangular areas around base. ;; Kent Cooper, 9 October 2013
(defun C:EDS ; = Elliptical Dome as 3d Solid (/ a1 a2 ht prec par ss ell pt ang) (command "_.undo" "_begin") (setq a1 (getdist "\nLength of one elliptical axis: "); = Axis 1 a2 (getdist "\nLength of other elliptical axis: "); = Axis 2 ht (getdist "\nHeight: "); = height prec (getint "\nNumber of segments per quadrant [precision]: ") par 0.0 ; initial ss (ssadd); initially empty ); setq (setvar 'ucsfollow 0) (setvar 'osmode 0) (setvar 'blipmode 0) (command "_.ucs" "_world" "_plan" "" "_.zoom" "_c" '(0 0 0) (* (max a1 a2) 1.05) "_.ellipse" "_c" '(0 0 0) (polar '(0 0 0) 0 (/ a1 2)) (/ a2 2) "_.shademode" "2d" ); command (setq ell (entlast)) (repeat (1+ prec) (setq pt (vlax-curve-getPointAtParam ell par) ang (angle '(0 0 0) (vlax-curve-getFirstDeriv ell par)) ); setq (command "_.ucs" "_zaxis" '(0 0 0) (polar '(0 0 0) ang 1) "_.ellipse" "_c" '(0 0 0) (trans pt 0 1); even though it will be up off UCS plane ht "_.extrude" "_last" "" (max a1 a2) "" "_.move" "_last" "" (list 0 0 (- (/ (max a1 a2) 2))) "" "_.ucs" "_world" ); command (ssadd (entlast) ss) (command "_.mirror" "_last" "" '(0 0 0) '(0 1 0) "_no") ; [redundant for first and last, but easier than distinguishing] (setq ss (ssadd (entlast) ss)) (setq par (+ par (/ pi 2 prec))) ); repeat (command "_.extrude" ell "" ht "") (ssadd (entlast) ss) (command "_.intersect" ss "") (command "_.undo" "_end") (princ) ); defun
SEANT
Groupie
Using: AutoCAD 2016
Status: Offline
Posted: 09.Oct.2013 at 18:42 |
I shall look into it promptly.
SEANT
Groupie
Using: AutoCAD 2016
Status: Offline
Posted: 09.Oct.2013 at 21:25 |
I can certainly confirm something amiss. The routine as posted earlier works on my desktop, but not on the laptop. I've isolated the problem to the Solid3D.Slice( surface As Autodesk.AutoCAD.DatabaseServices.Surface) call, but I haven't found out why it fails intermittently. AutoCAD may be haunted. I did modify the procedure a bit, and it now works on both of my machines. In case anyone's up for another go, I'll post the modified code. Due to a couple of reasons, all valid no doubt, posts from a "Newbie" containing attachments require moderator involvement. I'll attach the new code to a post directly following this one.
SEANT
Groupie
Using: AutoCAD 2016
Status: Offline
Posted: 09.Oct.2013 at 21:29 |
Here is the modified code. (see later updates)
Edited by Vladimir Michl - 18.Oct.2013 at 14:06
mmaurigi
Groupie
Using: AutoCAD 2009
Status: Offline
Posted: 09.Oct.2013 at 22:50 |
Thanks for the modified code. It seems to have work. However, the 3D solid was not a half dome, it was a dome on both sides of the XY axis. I had to slice it along that axis to get what I wanted. Also, I did get a message on the Command Line saying "Error Producing Solid".
Othe than that, it worked great.
