Please abide by the
rules of this forum.
| Author |
Topic Search Topic Options
philippe JOSEPH
Senior Member
Using: AutoCAD Mechanical 2017
Status: Offline
Topic: printing Posted: 21.Mar.2014 at 15:53 |
Yeah John, I have found where to find your visual styles on my screen, and it's with a clic where the red arrow is.
It's never too late.
Edited by philippe JOSEPH - 21.Mar.2014 at 15:57
John Connor
Senior Member
Using: AutoCAD 2018
Status: Offline
Posted: 12.Feb.2014 at 13:33 |
I think I'm going to need a translation.
First change your background to white. If you need something other than an isometric view of your 3D model, like a top or side view, then use FLATSHOT. That makes the most sense.
Edited by John Connor - 12.Feb.2014 at 13:34
<<AutoCAD 2015>>
philippe JOSEPH
Senior Member
Status: Offline
Posted: 12.Feb.2014 at 13:18 |
John + servicesdrafting, it doen't make doubts for me that I'm not making the good settings.
I succeded in having that image that you see with an opened port + :
The settings : Image filaire 2D ( aprox. wired 2d image ) + VSOBSCUREDEDGES : 6.
When I print I get a dark plot including hidden/dashed lines ( not a white image with only visible and hidden/dashed lines line with a FLATSHOT ).
Servicesdrafting, it looks like you could give me informations for a good plot.....
Thanks in advance.
servicesdrafting
Newbie
Using: AutoCAD2013
Status: Offline
Posted: 12.Feb.2014 at 12:35 |
You need to use other line type.
John Connor
Senior Member
Using: AutoCAD 2018
Status: Offline
Posted: 12.Feb.2014 at 11:35 |
I don't understand your reference to the "color of the volumes".
Why aren't you using a 3DHidden visual style?
<<AutoCAD 2015>>
philippe JOSEPH
Senior Member
Status: Offline
Posted: 12.Feb.2014 at 08:18 |
John, I can see the light !!!
I haven't tested all the settings of all the commands/variables listed here above.
I'd like to have the equivalent of the FLATSHOT command i.e. all the visible lines + all the hidden/dashed lines without the "color" of the volumes.
Edited by philippe JOSEPH - 12.Feb.2014 at 09:43
John Connor
Senior Member
Using: AutoCAD 2018
Status: Offline
Posted: 11.Feb.2014 at 16:45 |
philippe JOSEPH wrote:
John, if you don't see why not, I don't see HOW !
I know how to have different visual styles but I don't know how to have this particuliar one with that so wanted hidden dashed lines. |
OK...calm down. It ain't all that difficult. You need to set the VSOBSCUREDEDGES system variable to "1". The default is "0" To change the type of line that is being displayed as hidden look at the VSOBSCUREDLTYPE system variable. The values go from 1 to 11. This is covered in your AutoCAD Help file. Feeling better now?
<<AutoCAD 2015>>
sungik
Groupie
Using: autocad2012
Status: Offline
Posted: 11.Feb.2014 at 15:56 |
i am so sorry about it all. it just me that new bie for a cad
blackjeans
philippe JOSEPH
Senior Member
Status: Offline
Posted: 11.Feb.2014 at 15:54 |
John Connor
Senior Member
Using: AutoCAD 2018
Status: Offline
Posted: 11.Feb.2014 at 14:52 |
I don't see why not.
<<AutoCAD 2015>>
