RSS discussions
Discussion Discussion forum
Topic ClosedLine weight issue
 Post Reply Post Reply
Author
pizzle View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Topic: Line weight issue
    Posted: 13.Jun.2014 at 12:38
I have noticed recently that the line weights in my drawings are acting strange.
Everything seems and appears fine within AutoCAD, but as soon as I plot to PDF or plot direct to printer, the line weights mess up and some are thicker then others! There doesn't seem to be any pattern to certain lines that mess up, it appears to be fairly random.
This is really starting to annoy my now because I have a shed load of P&ID's that need amending with line weights that need to vary in thickness etc, and I simply can't complete the work while this is happening!
I have attached the original DWG file. If anyone can take a look and let me know if they have the same issue at their end OR shed some light on this and help me sort things out, that would be fantastic!
uploads/11333/C-PRO-PFD-320-00002_Option_2.dwg
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 13.Jun.2014 at 12:39
P.S. I have tried updating my graphics drivers etc but this hasn't helped.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 13.Jun.2014 at 13:06
Test the attached and tell us if you see any difference.
uploads/165260/C-PRO-PFD_JohnConnor.dwg
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 13.Jun.2014 at 13:19
Hi John,
Thanks for taking a look. Unfortunately, It is still the same.
I have attached a jpg to highlight a few trouble areas.
It just all looks a little bit un-crisp and slightly shabby. Which is not good when dealing with P&ID's with multiple lineweights etc.
If you can think of anything ells that may work, that would be great! I'm starting to pull my hair out! haha.
Thanks
Pete
uploads/11333/Example_for_John.zip
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 13.Jun.2014 at 13:36
Just how are you plotting to PDF?  Are you using the default AutoCAD DWG TO PDF.pc3 or something else?
I printed your drawing from directly from AutoCAD.  Next I created a PDF using the DWG TO PDF.pc3 default in AutoCAD.  I opened the PDF then printed it.  I compared the two.  There was no difference on my end.
My guess is either it is a printer driver problem or the fact that you are using some other program to create and print your PDFs.
Edited by John Connor - 13.Jun.2014 at 14:08
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 13.Jun.2014 at 14:05
Just using the standard 'plot to pdf' option
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 13.Jun.2014 at 14:13
How did it look once you plotted to pdf at your end John? Were the lines looking strange?
I have a feeling it may well be my adobe reader. I have opened and plotted the drawing to pdf using Trueview as well, and the problem is still there! So It can't be Autocad. It must be the pdf reade.
Would you agree?
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 13.Jun.2014 at 14:17
No, the lines did not look strange at all.  The two prints look identical.
Yes, I suppose it could be the version of Adobe Reader you are using.
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 13.Jun.2014 at 14:38
I'll dig further and see if I can find the problem
Thanks for your help anyway  Wink
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 13.Jun.2014 at 14:43
OK...good luck.
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,272 seconds.
