RSS discussions
Discussion Discussion forum
Topic ClosedAutocad Fatal Error (low Memory)
 Post Reply Post Reply
Author
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Topic: Autocad Fatal Error (low Memory)
    Posted: 26.Jun.2014 at 11:22
Originally posted by sysgen sysgen wrote:
I just right click MY COMPUTER ->select properties ->Advanced -> Performance Settings -> Advanced Tab
-> Changed Virtual Memory -
Thats how i adjust.
The .dwg  is more than 10MB not just for the same file but any files that has bigger sizes..
What settings did you actually use?
If your drawings are 10MB or more and your computer has only 4GB of RAM you are going to see a performance hit.
What is your hard drive capacity?  How much free space do you have?
<<AutoCAD 2015>>
Back to Top
agguloy View Drop Down
Groupie
Groupie
Using: 2015
Status: Offline
Direct Link To This Post Posted: 26.Jun.2014 at 06:17
hello,
not applicable command to cad might one of the cause of fatal error. 3d cad working then can slower its performance and causes fatal error. try not to corporate all your working drawings.
jaRIZ_raisa
Back to Top
sysgen View Drop Down
Newbie
Newbie
Using: Autocad 2014, Revit2011
Status: Offline
Direct Link To This Post Posted: 26.Jun.2014 at 02:12
Thats how i adjust.
Sysgen Outsource is a member of the Sysgen Group – a diversified and mutually reinforcing group of companies founded in 1991 to provide IT Consulting, IT Staffing, IT Training and IT-enabled services.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 25.Jun.2014 at 11:44
What is the size of the DWG file you are working with?
Does the problem happen with any drawing (even new ones) or just a particular drawing?
Usually out of memory errors are caused by a lack of sufficient virtual memory.
What exactly did you do when you changed your settings?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 25.Jun.2014 at 09:18
64bit windows Xp operating System..  and I adjust the Virtual Memory.. but still crashes and wanted to restart.
Back to Top
Vladimir Michl View Drop Down
Senior Member
Senior Member
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 25.Jun.2014 at 09:17
If you are using a 32-bit operating system, any application can use only 2GB max. Make sure you have enough virtual memory and disk space.
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 25.Jun.2014 at 08:13
When I was opening the file.. and working on it.. it crashed and tells it Fatal Error  out of memory - shutdown.
When I shut it down and restart teh Autocad.. after few minutes, still. it appears.. this is just recent..
I do have 4GB Ram but Autocad uses only 2G..
 can anyone knows how to fix this?
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,180 seconds.
