RSS discussions
Discussion Discussion forum
Topic ClosedAutocad 2014
 Post Reply Post Reply Page  12>
Author
Rico69 View Drop Down
Newbie
Newbie
Using: autocad
Status: Offline
Direct Link To This Post Topic: Autocad 2014
    Posted: 30.Jul.2014 at 03:17
Hello to you all.
I need some help please.
I lost my UNITS command. When I type it on the command line and or select from
the pull down menu this is what I get in return: unknown command "DDUNITS".
I am not a CAD guru, pretty new to this release
I typed on the command line several approaches I got from others like: ._units,   -units, un,
units.arx and system variable "demandload" set to 3.
None of the above worked. Could any of you out there please help me?
Thank you
Rico
happycad
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 30.Jul.2014 at 11:49
Are we to assume that the command used to work previously?
Did you make any changes to the CUI?
Did you undefine the command?
Have you tried resetting your profile?
Are there any other commands that mysteriously no longer work?
Have you tried going through the Ribbon to access the command?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: autocad
Status: Offline
Direct Link To This Post Posted: 30.Jul.2014 at 18:00
Thank you John.
Yes the command work previously
No changes to the CUI
I undefined and redefined the command
Have not try to reset the profile
So far this is the only command not working
I did try going through the Ribbon
happycad
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 30.Jul.2014 at 18:14
The other option would be to do a REPAIR of the installation which is not the same as an uninstall/reinstall.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: autocad
Status: Offline
Direct Link To This Post Posted: 30.Jul.2014 at 19:23
Ok Sir, How do i do that?
Please show me the steps
happycad
Back to Top
Robert_D View Drop Down
Senior Member
Senior Member
Using: BricsCAD v25, AutoCAD2006
Status: Offline
Direct Link To This Post Posted: 31.Jul.2014 at 00:26
Run the installation & opt for the "Repair" option.
Back to Top
Newbie
Newbie
Using: autocad
Status: Offline
Direct Link To This Post Posted: 01.Aug.2014 at 22:19
Robert, thank you.
If I run the repair, would I loose all the settings, work spaces and customization's I have done?
I also found that when I type at the command line appload units, it takes me to a dialog box where I can search for it.
I founded I clicked on load and it returns a samall dialog box saying: unitsres.dll not found.
I did search for it on the NET founded the "unitsres.dll" and downloaded. someone told me not to use it
because they usually come bundle with viruses. I believe the file is corrupted. Do you think you can send
me a copy of yours please, so I can re-inserted in the directory. I like to try this approach first, before
I do a repair.
Thanks again Robert
Be well
Edited by Rico69 - 01.Aug.2014 at 23:05
happycad
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 02.Aug.2014 at 12:26
The REPAIR option won't affect your settings.  It repairs or replaces corrupted or missing files.  Run it.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: autocad
Status: Offline
Direct Link To This Post Posted: 02.Aug.2014 at 19:00
Thank you John
Be well
happycad
Back to Top
Newbie
Newbie
Using: autocad
Status: Offline
Direct Link To This Post Posted: 06.Aug.2014 at 20:58
RE: UNITS COMMAND, RETURNS "unknown command DDUNITS.     (unitsres.dll not found
warning dialog box)
Thanks to all of you that did want to help me.
As you suggested to run the repair, I did one last search and found that the unitsres.dll under the AutoCAD folder was missing. I replaced it in the directory and now when I type the units command it returns the normal dialog box. I opened a drawing drew a couple of lines, selected the units command worked, save the drawing re-opened and now works fine. I believe that file was lost because AutoCad shuts it self off and I had to do a recovery file.
Thanks again.
happycad
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,188 seconds.
