RSS discussions
Discussion Discussion forum
Topic Closedinstallation error(code 1.248.1001)
 Post Reply Post Reply
Author
siddik View Drop Down
Newbie
Newbie
Using: 2004
Status: Offline
Direct Link To This Post Topic: installation error(code 1.248.1001)
    Posted: 26.Oct.2014 at 20:07
when installing the autocad error message shows code 1.248.1001 why?
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 26.Oct.2014 at 21:49
Do you have admin rights to your computer?
Did you try looking the code up on the Internet?
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 27.Oct.2014 at 10:46
Are you trying to install AutoCAD 2004 on a system running either Windows 7 or Windows 8?  If so then the problem may arise from the disparity between the age of your AutoCAD program (2004) and the newness of the operating system.  2004 is not supported under either OS so you either have to run it in XP compatibility mode or resort to a third-party add-on like Longbow to successfully run AutoCAD.
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,125 seconds.
