RSS discussions
Discussion Discussion forum
Topic ClosedAutoCAD Block Lookup Table
 Post Reply Post Reply
Author
CAD@thescenicroute.c View Drop Down
Newbie
Newbie
Using: Autocad 2014, Solidworks 2014
Status: Offline
Direct Link To This Post Topic: AutoCAD Block Lookup Table
    Posted: 23.Dec.2014 at 03:24
Hello,
I am having an issue with the lookup table in AutoCAD 2014. The table won't open, or is not visible, when trying to edit it through the Block Editor. Otherwise, the lookup action is operating correctly. When I try to open the table nothing pops up. I can't see the window elsewhere on the screen. Clicking anywhere produces an error sound until i hit escape  to get out of the (invisible) lookup table window. I have this issue with other blocks in different files.
Has anyone seen this, or similar issues? Any further recommendations for troubleshooting?
Thanks!
Jordan Woods-Wahl
AutoCAD 2014 NLM, windows 7
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 23.Dec.2014 at 12:25
It's possible that the reason the lookup table doesn't show up is because there are two grips on top of one another meaning the grip for the lookup table is being hidden by another grip.
Edited by John Connor - 23.Dec.2014 at 12:57
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 23.Dec.2014 at 15:13
Only one grip for the table. Nothing shows up behind it.  Having this issue when I create a new block and a new lookup in a new file. So, maybe its something system related.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 23.Dec.2014 at 15:17
Or maybe you are doing something wrong.
I can't think of any variables that would affect the display of the lookup table.  If you think it is system related then you might try a REPAIR (not an uninstall/reinstall!) of AutoCAD.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 23.Dec.2014 at 15:34
Something is affecting the display of the lookup table. It's like the window is popping up somewhere and I can't find it to click on it.
I can't find a system variable either.
Thanks for the help though!
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 23.Dec.2014 at 15:51
Zoom > Extents?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 23.Dec.2014 at 16:04
Repair didn't resolve the issue. I'm going to do a re install later today.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 23.Dec.2014 at 16:22
There is a recommended procedure you should follow posted at the AutoDesk website.
<<AutoCAD 2015>>
Back to Top
Koen123 View Drop Down
Newbie
Newbie
Using: ACAD 2013
Status: Offline
Direct Link To This Post Posted: 30.Jun.2015 at 13:55
Hi,
Did anybody find any answer to this problem, I seem to have the same thing..
Koen
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 30.Jun.2015 at 14:22
The OP recreated the block.
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,082 seconds.
