RSS discussions
Discussion Discussion forum
Topic ClosedAutoCAD Mechanical : AMSTLSHAP2D
 Post Reply Post Reply
Author
philippe JOSEPH View Drop Down
Senior Member
Senior Member
Using: AutoCAD Mechanical 2017
Status: Offline
Direct Link To This Post Topic: AutoCAD Mechanical : AMSTLSHAP2D
    Posted: 27.Jan.2015 at 13:29
We have recently moved to Windows 7 and my AutoCAD Mechanical was reloaded.
Although the same ( AutoCAD Mechanical 2012 ) I don't find the same profile library with the command AMSTLSHAP2D.
The "old but the same" release gave me also the English ( GB ) old profiles like : GB 706-88 , GB/T 11263-2005 , GB 9787-88 , GB 9788-88 , GB 9946-88 , ( also with Indian ( IS )) etc.
OK now I have the russian ( GOST ...... ) ones.
Anyone around the planet had the same crazy idea of inserting each one of the profiles available in each norm + size like I did with the AutoCAD file here enclosed ?, or an other idea because when you search old profile you will allways want at least all the dimensions to redraw it like length , radius, angles etc... and always a dimension or radius or angle you won't get.
My actual problem is that I have inserteretd blocks that are OK if the norm is in AutoCAD ( dynamic blocks ) but the one that don't have anymorer the norm inside AutoCAD are no more dynamic and are frozne in the olnly one dimension that I have inserted.
Edited by philippe JOSEPH - 27.Jan.2015 at 13:33
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,180 seconds.
