RSS discussions
Discussion Discussion forum
Topic ClosedText
 Post Reply Post Reply
Author
LS10 View Drop Down
Newbie
Newbie
Using: AutoCAD LT2012
Status: Offline
Direct Link To This Post Topic: Text
    Posted: 23.Feb.2015 at 11:42
Hi,
I'm using AutoCAD LT2012 and whenever i double click text to edit, it takes about 20 seconds before the edit text screen appears, however, if i type DDEDIT then the text editor appears immediately (as it should do)
Has anyone else encountered this problem? I am at a loss to explain.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 23.Feb.2015 at 14:48
What have you done so far to troubleshoot the problem?
<<AutoCAD 2015>>
Back to Top
LS10 View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 23.Feb.2015 at 14:53
I originally thought my title block was corrupted so i removed that and tidied it up but still nothing, i've purged and audited the drawings but still nothing, i've also tried changing the text style, still no joy. What confuses me even more is the fact it works properly by going through DDEDIT but try and double click it and it takes an age :(.
This is not limited to a single drawing, it's happening on every drawing i use unless it comes from an external source which leads me to think something i have is causing the problem, i just have no idea what else to do.
Thanks for replying by the way :)
Back to Top
Robert_D View Drop Down
Senior Member
Senior Member
Using: BricsCAD v25, AutoCAD2006
Status: Offline
Direct Link To This Post Posted: 23.Feb.2015 at 16:08
A (less than ideal) workaround would be to use Command Alias ED / Enter.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 23.Feb.2015 at 16:15
Have you installed all service packs?
<<AutoCAD 2015>>
Back to Top
ktahameed View Drop Down
Groupie
Groupie
Using: AUTOCAD16
Status: Offline
Direct Link To This Post Posted: 24.Feb.2015 at 06:53
thanks very good information
ABUASHIKA
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,102 seconds.
