RSS discussions
Discussion Discussion forum
Topic ClosedCan't perform boolean substraction
 Post Reply Post Reply
Author
bavdeyka View Drop Down
Groupie
Groupie
Using: AutoCAD2013
Status: Offline
Direct Link To This Post Topic: Can't perform boolean substraction
    Posted: 05.Mar.2015 at 23:08
Please have a look at my model. I can't perform boolean substraction on it.
Could you please prompt on what the problem is?
http://www.4shared.com/photo/Ep01Sbdkba/mul_1_.html
Edited by bavdeyka - 06.Mar.2015 at 12:31
Back to Top
Groupie
Groupie
Using: AutoCAD2013
Status: Offline
Direct Link To This Post Posted: 06.Mar.2015 at 06:30
I guess the first link is faulty, here's a download one: http://www.4shared.com/download/Ep01Sbdkba/mul_1_.dwg?lgfp=3000
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 06.Mar.2015 at 12:25
What program was used to create the 3D model?
What are you trying to extract from the model?
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Using: AutoCAD2013
Status: Offline
Direct Link To This Post Posted: 06.Mar.2015 at 12:58
This was created in Solidworks by another person.
It won't substract even from primitive blocks, such as box. So I'm sure that the problem is in this model.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 06.Mar.2015 at 13:00
Can't you reproduce the 3D model in AutoCAD?
<<AutoCAD 2015>>
Back to Top
philippe JOSEPH View Drop Down
Senior Member
Senior Member
Using: AutoCAD Mechanical 2017
Status: Offline
Direct Link To This Post Posted: 06.Mar.2015 at 14:11
Hello bavdeyka, can you still have the Solidwoks file or can you ask the other person to do a "save as .sat file with the good options" here shown.
maybe if it has be done as a .step or not with the good options you will get surfaces and not solids.
Then you will have to rotate by -90° around Z ( OK with UCS world ) then rotate by +90° around Y ( set a special UCS for this ) your model to have it in AutoCAD with the same way as Solidworks.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,182 seconds.
