Over 1.132.000 registered users (EN+CZ).
Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
bushtumbash
Newbie
Joined: 09.Dec.2014 Location: Mongolia Using: autocad 2012 Status: Offline Points: 2 |
Topic: Text problemsPosted: 16.Mar.2015 at 03:06 |
Hi guys. I would like to convert sinle line text to mtext. When use the txt2mtxt command, all of text combined one. How to convert lot of individual text without combining? is there any command option or add-ons?. Regards Bush
tumee
John Connor
Senior Member
Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 16.Mar.2015 at 10:30 |
It sounds like you select ALL the text in the drawing instead of a group of individual lines. Is that correct?
<<AutoCAD 2015>> |
Kent Cooper
Senior Member
Joined: 12.Mar.2013 Location: United States Using: AutoCAD2020, 2023 Status: Offline Points: 687 |
Posted: 16.Mar.2015 at 14:19 |
You can use Text1MtextJust2.lsp, with its T1MJ command, available here. The incentive behind making it was to preserve the justification of the Text objects, rather than have their justifications always end up on the top edge somewhere, but in the process it does convert each one among a multiple selection separately.
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,130 seconds.
Text problems
Topic Options
bushtumbash wrote:
