RSS discussions
Discussion Discussion forum
Topic Closed3D model
 Post Reply Post Reply
Author
Bud View Drop Down
Groupie
Groupie
Using: AutoCAD 3D
Status: Offline
Direct Link To This Post Topic: 3D model
    Posted: 30.Apr.2015 at 12:17
Have used Solid works before but new to AutoCAD 3D, can you size parts after creating them as in Solid works or do you need to size before ?
Back to Top
philippe JOSEPH View Drop Down
Senior Member
Senior Member
Using: AutoCAD Mechanical 2017
Status: Offline
Direct Link To This Post Posted: 30.Apr.2015 at 12:59
Hello Bud, Autocad 2D can be with parameters but not AutoCAD 3D.
Only the initial solids can be controled with parameters, for example with the properties palette ( Ctrl + 1 ).
A cube can be updated easily but if you add a hole or a chamfer or anything it will turn to be modified with the 3D commands only.
We have also colleagues that are working with Solidworks and I can give indication to use models from AutoCAD to Solidworks and the contrary.
Eventually see my file : 3D SOLIDS 01.dwg right here in the site in the CAD/BIM Blocks library.
Launch a search with the file name or a part of it.
Ask for more and have a good day.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,082 seconds.
