Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
John Connor
Senior Member
Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Topic: Auto CAD UnitsPosted: 07.May.2015 at 16:58 |
The OP is working in metric units.
<<AutoCAD 2015>> |
Lokislady85
Newbie
Joined: 14.Oct.2014 Location: United States Using: AutoCAD2014 LT, Inventor2012, 3DS MAX, FASTCAD7.5X Status: Offline Points: 17 |
Posted: 07.May.2015 at 16:36 |
If all else fails find something in the drawing that you know its true size (i.e. doorways are generally between 3 and 3'6") and see how it shows up using the MEASURE command/button.
HenryT
Newbie
Joined: 26.Nov.2010 Location: South Africa Using: AutoCAD 2010 Status: Offline Points: 9 |
Posted: 05.May.2015 at 12:32 |
Hi John,
Thank you very much for your quick response. I will have a look and see if this will resolve my problem. |
Draughting and boardsports
John Connor
Senior Member
Posted: 05.May.2015 at 11:21 |
You check the scale of objects in the drawing? Why don't you use the -DWGUNITS command? It will tell you what units were used to create the drawing.
<<AutoCAD 2015>> |
HenryT
Newbie
Posted: 05.May.2015 at 08:50 |
Good morning all,
I have been working with Auto CAD for quite some while now and I still get stuck on this problem. I get given a loft of drawing that were done in 3 party software so when I receive a drawing that I need to work on I always start off with the what the current scale a the drawing is.(sometimes the drawing gets done in meters in the 3 party software and when I pull it into Auto CAD it interprets the meters as millimetres which means I basically have to scale the current object with a 1000 so that it would be the correct size. I have always done this by checking the scale of the objects in the current drawing. I have attached a dwg. where I adjusted the units three times (Millimetre ,Meter and Kilometre) but when I draw A line of 1000 units long ,in all three unit types the line is the same length .Common sense tells me that the line drawn in meters would be longer than the line drawn in millimetres ,same when it comes to the length difference between the one drawn in meters and the one line in kilometres. So basically when I open a dwg. how would one know the current size (when measuring ) of an object as well as how would I change my drawing units so when I measure an object the current dimension displays either millimetres ,meters or whatever I would like the units to be. Can you please assist me with this problem? uploads/151088/Henry.dwgHenry Klopper |
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,145 seconds.
Auto CAD Units
Topic Options
