Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
micallen
Newbie
Joined: 14.May.2015 Location: United States Using: ACAD 2011, SW 2015 Status: Offline Points: 12 |
Topic: Stencil letters and numbersPosted: 14.May.2015 at 14:16 |
I need to cut some numbers on our plasma. Does anyone have stencil numbers and letters in a DWG or DXF format I could get?
Thanks, Micallen
__________________
Micallen |
John Connor
Senior Member
Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 14.May.2015 at 16:00 |
What font style?
<<AutoCAD 2015>> |
micallen
Newbie
Posted: 14.May.2015 at 17:01 |
1st choice would be Swis 721 BdOul BT, but Arial would do.
__________________
Micallen |
Robert_D
Senior Member
Joined: 21.Oct.2013 Location: United States Using: BricsCAD v25, AutoCAD2006 Status: Offline Points: 215 |
Posted: 14.May.2015 at 17:03 |
micallen
Newbie
Posted: 14.May.2015 at 17:28 |
How can that text be converted into Polylines? Seems I used to know how to do that... long ago.
__________________
Micallen |
John Connor
Senior Member
Posted: 14.May.2015 at 17:42 |
You might first trying using the Express Tools command for exploding text. TXTEXP
<<AutoCAD 2015>> |
Robert_D
Senior Member
Posted: 14.May.2015 at 17:43 |
Express tools may have an explode text command.
If not, there are explode text lisp routines out there. |
micallen
Newbie
Posted: 14.May.2015 at 17:46 |
Works like a champ. Thanks !!
__________________
Micallen |
John Connor
Senior Member
Posted: 14.May.2015 at 17:47 |
Certain letters might require a little editing.
<<AutoCAD 2015>> |
Kent Cooper
Senior Member
Joined: 12.Mar.2013 Location: United States Using: AutoCAD2020, 2023 Status: Offline Points: 687 |
Posted: 15.May.2015 at 21:29 |
The company may not exist any more (I can't find an active website, but see, for example, http://www.softscout.com/software/Engineering/Computer-Aided-Design-CAD/Letterease.html), but we used to have a specialty text program called LetterEase, from Cadware, Inc. It did all kinds of neat things with text in AutoCAD, including kerning. It had a bunch of fonts available (you bought the program plus however many fonts you wanted), including several Helveticas (like AutoCAD's Swiss family) -- regular, light, bold, condensed, etc. Each one came in several .SHX formats (outline only, high- and low-density filled) at a time when TrueType fonts couldn't be used, and even when TrueType came into the picture, the .SHX fonts generated and loaded much faster. And, each font came with a folder containing each character as a Block, which when Exploded yielded Polyline outlines (and parallel-Line infills for the filled ones). They had real curved edges where appropriate, and were very well-constructed, so they looked good at any size. If you can find a place to get LetterEase fonts, Exploding the outline-only Blocks would give very good results.
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,133 seconds.
Topic Options
John Connor wrote:
