RSS discussions
Discussion Discussion forum
Topic Closed.dwg file unable to open
 Post Reply Post Reply
Author
bertramtanner33 View Drop Down
Newbie
Newbie
Using: AutoCAD2013
Status: Offline
Direct Link To This Post Topic: .dwg file unable to open
    Posted: 22.Jun.2015 at 15:51
This file is Unknown and I need to open. ---->>> Lakewood scan.dwg   How can I open it ?
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 22.Jun.2015 at 16:44
It's a DWG file so first I would try opening with AutoCAD.  If that doesn't work then I'd use DWG TrueView.  What program was used originally to create the drawing?  You do know that AutoCAD-clones can save to the .DWG file format don't you?
<<AutoCAD 2015>>
Back to Top
aidenburke View Drop Down
Newbie
Newbie
Using: AutoCAD2013
Status: Offline
Direct Link To This Post Posted: 30.Jun.2015 at 09:37
This AutoCAD feature was added in AutoCAD 2006, when your AutoCAD software suddenly crashes due to hardware malfunction, power failure or any other cause leading to its abrupt closing then AutoCAD will show drawing recovery manager next time you open it.
This recovery manger provides a simple interface to locate autosave and backup files without manually searching them over your system. Drawing recovery manager will only appear in instances of sudden system crash, you can also open Drawing Recovery manager from
Application menu>> Drawing utilities >> Open the drawing recovery manager
When you begin new session after system crash you will be welcomed by drawing recovery dialog box.
Close this dialog box and look towards the left of your drawing area to locate drawing recovery manger palette. You will find a specification tree with autosave and backup files in the list, click on files you will see their preview in panel at the bottom. Double click drawing which you want to recover and you can now continue with your work.
Or you may visit http://communities.bentley.com/products/microstation/w/microstation__wiki/2939.recovering-corrupt-dgn-and-dwg-files-cs
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 30.Jun.2015 at 11:41
bert:  Do NOT follow any advice given by aidenburke and do NOT click on the link.
Think about it.  Why would someone purportedly trying to help with an AutoCAD-related problem ask that you click on a link for Bentley Microstation?
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,156 seconds.
