RSS discussions
Discussion Discussion forum
Topic ClosedIssue with dwg files
 Post Reply Post Reply
Author
 Rating: Topic Rating: 1 Votes, Average 5,00  Topic Search Topic Search  Topic Options Topic Options
diego.soler View Drop Down
Newbie
Newbie
Using: AutoCAD2013
Status: Offline
Direct Link To This Post Topic: Issue with dwg files
    Posted: 17.Nov.2015 at 13:06
Hello experts,
I have a dwg file that is corrupted or encrypted and I need to fix it.
Is there any tool I can use to check the integrity of the dwg files.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 17.Nov.2015 at 15:38
There is a big difference between a corrupted drawing and one that is encrypted.
If a drawing is corrupted then try using the RECOVER command to open it.  If the drawing can be opened but not saved for some reason then try using the Overkill, -Purge (Regapps then All) and Audit commands on it to clean it up.  Once you do then maybe, just maybe you can save it but I'd recommend saving it under a different name.
If the drawing is encrypted (do you mean password protected?) then kiss it goodbye because you aren't going to open it.  Period.
Edited by John Connor - 17.Nov.2015 at 15:39
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: AutoCAD2013
Status: Offline
Direct Link To This Post Posted: 19.Nov.2015 at 11:20
The RECOVER command did not help. the file is not opened.
Back to Top
Vladimir Michl View Drop Down
Senior Member
Senior Member
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 19.Nov.2015 at 11:28
If the drawing is encrypted by password protection, it will politely ask for a password on open.
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 19.Nov.2015 at 11:34
Who gave you the drawing?
<<AutoCAD 2015>>
Back to Top
kristensenn View Drop Down
Newbie
Newbie
Using: AutoCAD2013
Status: Offline
Direct Link To This Post Posted: 19.Nov.2015 at 14:21
Maybe a quick check suggested by the principal themselves with various steps
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCAD-File-Corruption.html
Otherwise, try using  DWG Recovery Toolbox s/w just to make the file legitimacy for recovery chances of prev copies.  http://www.oemailrecovery.com/dwg_recovery.html
Hopefully from Autocad autosave by default, it should have saved dwg file automatically with ac$ as default extension, and if we can just find the *.ac$ file and change ac$ to dwg. There may be slight chance. The AutoCAD's autosave file is saved in this folder: C:\Users\[User Name]\appdata\local\temp\. typically.
Back to Top
Newbie
Newbie
Using: AutoCAD2013
Status: Offline
Direct Link To This Post Posted: 19.Nov.2015 at 14:24
Look at it this resource. Perhaps you will find there more useful information.
http://www.instructables.com/answers/Autocad-CorruptInvalid-File/
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 19.Nov.2015 at 19:24
diego: Attach a copy of the drawing to your next post.  Maybe someone here will have better luck unless of course it is encrypted in which case neither you nor anyone else here will be able to open it without the password.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: AutoCAD2013
Status: Offline
Direct Link To This Post Posted: 29.Nov.2015 at 22:09
Thank you guys for your feedback and help. Sorry, that long time did not respond. This is because the issue was solved and I forgot to tell.) Thank you!
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,125 seconds.
