RSS discussions
Discussion Discussion forum
Topic ClosedAutoCAD Plant 3D flanges issue
 Post Reply Post Reply
Author
Conaill31 View Drop Down
Newbie
Newbie
Using: Autocad 2014
Status: Offline
Direct Link To This Post Topic: AutoCAD Plant 3D flanges issue
    Posted: 13.Jan.2016 at 23:46
Hi I am doing some 3D modeling and getting pressure class error.
If I create a tank in equipment block it is giving tank 300lb flanges.
I am using CS150 spec which has 150lb flanges in it's spec.
If I try and route pipe I am getting error:
Cannot find flange in CS150 spec
 Pressure Class 300
Flanged connection failed due to properties mismatch
If I try and modify equipment it will not allow me change 300lb to 150lb
for flanges on equipment block.
Anybody know a fix for this?
Conaill
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 14.Jan.2016 at 12:12
You might try asking your question over at the AutoCAD Discussion Groups in the Plant3D section.  You'll probably get more help there.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: Autocad 2014
Status: Offline
Direct Link To This Post Posted: 15.Jan.2016 at 00:00
I have figured this out. Some equipment blocks allow you to modify flanges
and some do not. This may because I am using a student version.
Pumps can be modified but tanks cannot be modified. If you click
on block you should see a brown pencil symbol which allows you
to modify block and pressure class rating. If no pencil then no modify.
Conaill
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 15.Jan.2016 at 11:45
It has nothing to do with the fact you are using a student version.  As AutoDesk plainly states on its website student versions of their programs are fully functional meaning they operate the same way as the retail version.
<<AutoCAD 2015>>
Back to Top
Banner.Man View Drop Down
Newbie
Newbie
Using: AutoCAD
Status: Offline
Direct Link To This Post Posted: 26.May.2016 at 16:57
On the tank, hold the CTRL key down and select the nozzle. Then you'll get the pencil and can edit the nozzles pressure class.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,112 seconds.
