RSS discussions
Discussion Discussion forum
Topic Closedtext height in different scales.
 Post Reply Post Reply
Author
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Topic: text height in different scales.
    Posted: 02.Feb.2016 at 16:44
Metric paper sizes but imperial units?  Now that's a recipe for disaster.
Personally I'd put any text or dimensions in the layout and forget using scale factors.
<<AutoCAD 2015>>
Back to Top
philippe JOSEPH View Drop Down
Senior Member
Senior Member
Using: AutoCAD Mechanical 2017
Status: Offline
Direct Link To This Post Posted: 02.Feb.2016 at 14:03
Hello Zuhaib, if you place your texts in model space you should multiply the height of your layout height by the scale of the viewport ( if any ).
3/32" = 1/128 so if you want to have 3.5 mm height text printed at scale 1/1 on an A1 paper size multiply the 3.5 height by 128 ( 448 ).
By the way, what standards are you using : Imperial or Metric ?
1/128 is the ZOOM that you will apply when setting your view ports if you don't use the scale available on your computer in the scale list.
Eventually, place here an example of your drawings so we can take a look at it to see the settings, dimensions, etc...
Eventually take a look on the internet for example at CADTutor - Scale Factors - Imperial and Metric.
Edited by philippe JOSEPH - 02.Feb.2016 at 14:10
Back to Top
Zuhaib View Drop Down
Groupie
Groupie
Using: AUTOCAD 2018
Status: Offline
Direct Link To This Post Posted: 02.Feb.2016 at 12:03
hi,
   I have a layout plan in format of dwg. and i want to set it in different panels on paper size of A3 and A1, and my drawing scale is 3/64" in A3 and scale 3/32" in A1. So which text height will be use in both scales in 1 model space.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,086 seconds.
