RSS discussions
Discussion Discussion forum
Topic ClosedDYNAMIC BLOCK
 Post Reply Post Reply
Author
Zuhaib View Drop Down
Groupie
Groupie
Using: AUTOCAD 2018
Status: Offline
Direct Link To This Post Topic: DYNAMIC BLOCK
    Posted: 08.Feb.2016 at 06:53
HOW CAN I MAKE DYNAMIC BLOCK.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 08.Feb.2016 at 11:38
The basics are covered in your AutoCAD Help file.
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS1a9193826455f5ffa23ce210c4a30acaf-6e6a.htm,topicNumber=d0e73035
What do you want to create as your first dynamic block?
Edited by John Connor - 08.Feb.2016 at 12:33
<<AutoCAD 2015>>
Back to Top
HRamesh View Drop Down
Newbie
Newbie
Using: autocad
Status: Offline
Direct Link To This Post Posted: 06.Mar.2016 at 09:51
I have down loaded the dynamic block for beds but when i insert it to My autocad for mac it is found that it is not Dynamic block as the controll points are not seen.Can some one help me pl.
Back to Top
Vladimir Michl View Drop Down
Senior Member
Senior Member
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 06.Mar.2016 at 13:46
Please note that some DWGs are not dynamic blocks (directly) but rather drawings containing dynamic blocks. So try to explode the INSERTed DWG or use the INSERT command to choose a block to insert.
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,107 seconds.
