RSS discussions
Discussion Discussion forum
Topic ClosedGood PDF to DWG Conversion?
 Post Reply Post Reply
Author
showtime130 View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: Good PDF to DWG Conversion?
    Posted: 05.Jul.2016 at 18:28
I'm looking for a converter that will convert compound arcs in a PDF to arcs in a DWG instead of splines. What I am running into is that when I bring in a PDF that was saved to DWG all the arcs are splines. I can change the splines to polylines but that leaves a lot of unwanted vertices, which is a pain when it is applied to a mill/router machine.
In short I want to find a simple converter that will take PDF arcs to DWG arcs without making them splines. Or, use an Arc command that will change splines to arcs instead of PEDIT that changes them to polylines and a bunch of vertices.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,195 seconds.
