Discussion forum
?CAD discussions, advices, exchange of experience
Post Reply
| Author | |
dolau
Groupie
Joined: 28.Jun.2016 Location: United Kingdom Using: autocad LT2023 Status: Offline Points: 43 |
Topic: splinePosted: 12.Mar.2018 at 10:30 |
I have to start preparing drawings joining a number of points with a polyline representing a flexible pipework system joining up a number of heads on a scale drawing I guess SPLINE is the most appropriate way of doing this and seems to work although I have always struggled to draw one that isnt closed What I need to do is measure the length of the 'pipework' system or spline length Looking at properties it prepares the area under the shape created which I am sure is useful for some things Any ideas how I get the length of a spline once drawn Thanks PS - any idea when F8 to get ortho on a drawing might come back?
Andrew
John Connor
Senior Member
Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 12.Mar.2018 at 11:58 |
F8=Orthomode hasn't gone anywhere.
The length of a spline is returned when you issue the LIST command then select the spline. Edited by John Connor - 12.Mar.2018 at 12:01 |
<<AutoCAD 2015>> |
dolau
Groupie
Posted: 12.Mar.2018 at 12:03 |
For a while if I used F8 the drawing would freeze and I had to select the icon from the menu bar at the bottom of the screen- just tried it and it is back There was some discussion on here about it at the time Great thanks
Andrew
John Connor
Senior Member
Posted: 12.Mar.2018 at 12:45 |
Are you current with the latest service pack?
I have not heard or read anything about the F8 key locking up AutoCAD. |
<<AutoCAD 2015>> |
Kent Cooper
Senior Member
Joined: 12.Mar.2013 Location: United States Using: AutoCAD2020, 2023 Status: Offline Points: 687 |
Posted: 12.Mar.2018 at 14:54 |
If you want to draw the length at the Spline [or other object(s) with linearity] as a piece of Text, >>here<< is a thread with some routines to do that. The older ones put the Text at the start of each object; my newer one at Post 26 puts it at the midpoint.
> "...I have always struggled to draw one that isnt closed." Read about the Spline command in Help. Are you using the Close option to end the command, thinking that "closing" means completing the command, rather than taking the Spline back to Close to the starting end? Just hit Enter instead to end the command without Closing back to the start. Edited by Kent Cooper - 12.Mar.2018 at 14:59 |
Post Reply
Tweet
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
This page was generated in 0,164 seconds.
spline
Topic Options
